Thread: Help again with trans shifting a bit hard
Results 1 to 9 of 9
  1. #1 Help again with trans shifting a bit hard
    College Park, MD
    Man I'm getting tired of this. Just when I get to finally start enjoying my car after all the hard work I put in, something like this pops up.
    Let me give you some history. Got the car in May, dropped the trans and changed ALL the trans solenoids to the components that Dave @ Triple Edge sells (all high quality Borg Warner stuff), filled it with Dex 6, and everything was peachy other than needing the engine replaced, which I did in August. The car has had NO problems since then.
    So here in MD we just got a lot of snow, and the weather is really cold. I've had no problems for the past few days, was able to drive around just fine; car never got stuck, never gunned the engine in the snow.
    Anyway, was driving to work this morning, and I'm cruising at about 30-35MPH. The trans shifts from 2nd gear to 3rd gear, and it shifts HARD. Not hard as in banging, but the car lurches forward at the gear change. I thought I hit a bump, so I try it a few more times, and, yep, it shifts hard from 2nd gear to 3rd gear. 1st to 2nd is perfectly fine. After a little while, it sort of goes away. Also, it might be just me, but I think that 2nd gear is finishing at a too high RPM before it shifts into 3rd. I think. I might be wrong.
    When I got to work I checked the trans fluid and the fluid level. It's still red, not burnt, no funny smell, and the level is perfect.
    What could be causing this? Would it be the cold weather (I doubt it)? Or is this a far worse problem that I'm hoping is not?
    I really don't have any money or time for a new trans or to be messing around with this right now.
    Would a shift kit be an easy fix me up?
  2. #2 Re: Help again with trans shifting a bit hard
    Outer Space
    what is your gear ratio? The reason why I ask, is that when I got a new transmission the ratio was different. I had to reprogram my PCM...because it was shifting hard.
    Have you dropped the pan to see if you have any metal chunks in it?
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Help again with trans shifting a bit hard
    College Park, MD
    Quote Originally Posted by Lawngoose View Post
    I have no idea what the gear ratio is for the transmission.
    So far, since I had the car, I dropped the trans pan THREE TIMES. There have been NO chunks in it at all. The last time I changed the trans fluid was back in early August. I'd think that trans fluid should last at least 6 months to a year, no?
  4. #4 Re: Help again with trans shifting a bit hard
    Tofu Delivery Boy Lsick7's Avatar
    MO
    Same thing happened to me. I had my trans swapped and wasn't informed as to just how important the tune was with 3.29s and it shifted like dirt. Now it's tuned for those gears and it shifts beautifully.
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  5. #5 Re: Help again with trans shifting a bit hard
    College Park, MD
    Quote Originally Posted by Lsick7 View Post
    Well, the thing is that I didn't exactly do a rebuild. All I did was change all the solenoids in the trans while I was in there. I don't think that would warrant me to tune the PCM would it?
    And here's a small update.
    Just got back from a shop on my way home.
    NO error codes. Nothing. Not for the transmission or the engine.
    I really didn't feel it that much driving home. Everything felt normal. Car didn't do anything weird. I also pushed the car a bit, and everything felt normal.
    When I was in the shop, I told the mechanic that I changed the trans fluid about 4-5 months ago, and then inquired whether or not it made any sense for me to change it again due to this issue. He said that I shouldn't have to. Since he's not trans privy, he recommended me to another place. Don't have plans to go over there at the moment.
    So what do you guys think now? Just do a shift kit?
  6. #6 Re: Help again with trans shifting a bit hard
    Did you do the rebuild yourself? If you did...did you use a transmission from a GT or an H-Body? GT's have 3.29's and some of the H-Body's or even the Regal had some funky gear ratios like 2.82's and 3.05's.
  7. #7 Re: Help again with trans shifting a bit hard
    Jul 2008
    sumter,south carolina
    get it scanned for codes
    02 GTP with mods 05 GP for DD
  8. #8 Re: Help again with trans shifting a bit hard
    College Park, MD
    I just posted the update in my last post where I stated that I already did that and there were absolutely NO codes at all.
  9. #9 Re: Help again with trans shifting a bit hard
    Jul 2008
    lol my bad... good luck
  1. Hard shifting and slipping?
    By Lonestargp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-15-2009, 11:56 PM
  2. Hard shifting
    By Seagya in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:50 AM
  3. 2000 GT shifting really hard
    By c002529 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-04-2009, 12:08 AM
  4. BAH! Was Shifting hard....now shuddering
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-29-2009, 01:24 AM
  5. hard/slow shifting?
    By codyc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2009, 02:14 PM
