Thread: 4T65E Hard Shift-Solution
Page 8 of 8 FirstFirst ... 678
Results 141 to 147 of 147
  1. #141 Re: 4T65E Hard Shift-Solution
    New York
    Very smart..............!!!
    45,500 Hits on this thread going back 7 years now AND STILL NO STICKY!
    Not sure what the moderators are afraid of????????????............
  2. #142 Re: 4T65E Hard Shift-Solution
    Jul 2010
    Coquitlam,BC,Canada
    PM a moderator or move along. Getting old where every post you make is about "no sticky".
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #143 Re: 4T65E Hard Shift-Solution
    New York
    Quote Originally Posted by Bronco Boy View Post
    Really.....................??????????????
  4. #144 Re: 4T65E Hard Shift-Solution
    Jul 2017
    NE
    Did you get the coolers from zzp and everything came with it?
  5. #145 Re: 4T65E Hard Shift-Solution
    New York
    I got my Long LPD 18,000 GVW coolers from amazon or ebay:
    https://www.amazon.com/Long-Tru-Cool.../dp/B005XZXB1M
    The coolers come with everything you need: The cooler, hoses, mounting brackets, hose clamps, nut and bolts for the mounts etc.
    I used 2 coolers, one on each side in the nose in front of the condenser since I figured I could get them in without removing anything from the bottom front of the nose. If I was doing the install today I would use the biggest Long LPD cooler I could mount in the space or the Long Tru Cool Max if you can get it in place. My installation was done in 2009, 8 years ago, and still perfect, GP used as a DD all year round.
  6. #146 Re: 4T65E Hard Shift-Solution
    Jan 2021
    Ohio
    I know it's a old thread, but I'm getting ready to do this to my 01 Grand Prix SE, with 107,500 on the clock.
    Slightly hard shifts after a few miles. Not real hard or anything. Probably won't get to it till the spring though. I'll be happy to get 20,000 more out of the trans, as l only put a few thousand miles a year on the car.
    I'll probably do the trans cooler too.
    You say the one cooler the one fellow linked to on Amazon will be good for these cars?
  7. #147 Re: Soluci?n de cambio duro 4T65E
    Dec 2022
    Charlotte
    [Hello, I would like some help in knowing how to change the pistons, I want to replace them but I don't have a clear idea of how to remove the spring that is stuck on the piston, if you have any video or some instructions on how to do it I would be grateful
  1. 5th brake hose "hard line" solution ~$6
    By alacran in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2015, 01:18 AM
  2. 4T65E-HD lockup issue - engages really hard
    By paulaxe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2009, 09:25 PM
  3. hard shift
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-30-2008, 09:03 PM
  4. 5th brake hose -hard line solution ~$6
    By alacran in forum How To Write-Ups/Tech Tips
    Last Post: 10-02-2008, 08:18 PM
  5. Why is my 1st to 2nd shift so hard?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-26-2008, 08:35 AM
