Thread: Tranny removal
Results 1 to 2 of 2
  1. #1 Tranny removal
    SE Level Member NEOHIO25's Avatar
    Jul 2008
    NEOhio
    Does anyone have step by step instructions for removing a tranny from a '98 GTP? 4th gear is kind of "floating" into gear. I got two quotes from the tranny shop, 1 if they take it out and rebuild and 1 if I take it out and drop it of to them. Just woundering how difficult it is and if I might be able to save a few bucks.....thanks in advance.
    SLP headers/3.4 pulley/thrasher CAI/dynomax exhaust w/ cat delete/AL 104's/180* drilled T-stat/1.84 RR's/ poly mounts/UD WP pulley/MSD wires/TB spacer/GMPP Handling Kit
  2. #2 Re: Tranny removal
    SE Level Member singularity's Avatar
    Houston, Tx
    simplest form of doing it yourself. I have never done it, but if i were going to attempt to, i would do it this way.
    -Jack up car as high as you can get it.
    -Drain tranny fluid, and coolant
    -remove radiator hoses / transmission hoses / intake piping.
    -remove wheels / axles
    -unbolt steering rack
    -unbolt engine cradle with jackstand/wood holding it up.
    -Gently lower engine enough to gain access to the top of the transmission.
    -unbolt tranny, pull out, unbolt torque convertor from flexplate
    -remove transmission from engine.
    install would be in reverse order, and make sure to top off all fluids.
    Thats how i would go at it. Im sure you would have to remove the exhaust crossover pipe, but i would rather just pay a shop to do it for me lol. I spent enough time on my last 2 turboed 240sx's for a lifetime of cars.
  1. Rear Hub Removal
    By trenaro in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2009, 06:18 PM
  2. tranny removal Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-26-2009, 05:14 PM
  3. console removal
    By razoredge in forum Audio, Security & Visual Electronics
    Last Post: 12-18-2008, 10:25 PM
  4. bose removal
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 01:20 PM
  5. Downpipe and Cat removal
    By $03gp/gt$ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-18-2008, 10:35 AM
