Thread: Strange Trans. problem...help!
Results 1 to 16 of 16
  1. #1 Strange Trans. problem...help!
    SE Level Member lastonemade02's Avatar
    Missouri
    I have a 98 bonneville, and if I step on the gas hard from a DEAD STOP the whole front end shakes violently. Took to a trans. shop and of course they wanted to rebuild it for $2500 saying the prob. was a bad gears design and the gears were not meshing correctly or some bs to that effect. He claimed the trans would completely fail in the very near future. Since then I just babied it off the line and have had no issues at all. 2 years later I'm still driving it(only if I hit the gas too hard from a dead stop) Anybody have a clue to what this problem is? I love this car but cannot afford a new tranny.. Thanks!
  2. #2 Re: Strange Trans. problem...help!
    GT Level Member Gregorius's Avatar
    Davenport, IA
    My dad has a 99 LeSabre and it's been doing the same thing for years. Drives fine, and runs perfect, even WOT downshift into 1st at 20mph. But mashing it more than half throttle from a stop, and the car shakes hard and shimmies, like the tires have broken loose and are wheel hopping, until you let off the gas. It'll do it hot or cold, and consistently.
    I'm thinking it's caused by the input clutches cycling in and out rapidly, caused by low initial trans oil pressure, because it never slips or shakes after it has had RPM's on it, i.e. the WOT downshift into 1 doesn't slip.
    There is an idea I'm going to try. Like a brake stall test. Hold the brakes down hard, then give it maybe 1/4 throttle for a few seconds, let the pressure in the trans build, then mash it and let off the brakes.. If it doesn't shake on the mash, I'm thinking that would kind of verify the low pressure..
    I'm guessing there is a partially blown out gasket somewhere on the Valve body or Channel plate. Input piston seals from the factory are weak on 4t65e's also. That makes sense because the issue is "static", not getting worse over years.
    Fixing any of that basically requires pulling the tranny out, and if ya got the damn thing out, might as well at least do a light rebuild (gaskets, seals, frictions etc) That's what anyone who has done it before, is thinking. Unless you are just going after a known bad solenoid on a low mile trans..., well I'd be close to suicidal if I went thru to time and hassle to pull the trans to replace a single part, and have something else give out 500 miles later. Drive it till it dies.
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  3. #3 Re: Strange Trans. problem...help!
    Missouri
    Drive it till it dies.. LOL That's what I was thinking.... thanks
  4. #4 Re: Strange Trans. problem...help!
    swap your axles first. then see whats up with it. the axles are most likely your problem as broken transmission parts dont cause vibrations.
  5. #5 Re: Strange Trans. problem...help!
    Missouri
    when you say "Swap" the axles, do you mean replace them? ...and how much would that cost? I'll be paying a mech. to do the work.
  6. #6 Re: Strange Trans. problem...help!
    Wausau, WI
    Quote Originally Posted by lastonemade02 View Post
    it depends......do you mean gm parts or aftermarket.......the shafts themselves can be anywhere from $90 to $955 list price from gm each...plus labor... so are you taking it to aftermarket mech. shop or the gm stealership?
  7. #7 Re: Strange Trans. problem...help!
    Wausau, WI
    I would lean towards the axles as well........for what its worth.
  8. #8 Re: Strange Trans. problem...help!
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    def look into the axles or 1 axle as being the problem, i have also seen bad inner tie rod do some things under extreme pull. still i would lean towards axle =)
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  9. #9 Re: Strange Trans. problem...help!
    Apr 2009
    Baton Rouge, Louisiana
    Hmm, I was never thinking tranny either. I am leaning towards axel as well, maybe even a bit of chassis and suspension as well.
  10. #10 Re: Strange Trans. problem...help!
    you can get the "stage 1" axles from ZZP that have grease ports on them. if you have the money i would go with those. they are only $90 each for them.
  11. #11 Re: Strange Trans. problem...help!
    Missouri
    OK Two different guys have told me that it's not the trans. at all! They say it's the MOTOR MOUNTS. Makes sense. I'm gonna have them looked at here at the local Goodyear.
  12. #12 Re: Strange Trans. problem...help!
    SE Level Member Jimmy Dodge's Avatar
    Brantford, Ontario
    I'm having the same issues. only in 1st and only once it is warmed up. if it's cold there's no slippage. when it's warm it's like having a 4000 stall "strip" torque converter in it, unless you baby it OR if i pull it into 1st gear and shift manually it won't slip.
    this problem is not the axles. if the problem was shudder only, I would side with y'all.
  13. #13 Re: Strange Trans. problem...help!
    Apr 2009
    stockton ca
    my 98 gtp sorta did something like that this am but it was torque converter lockup suck on and delay in shift codes that came up
  14. #14 Re: Strange Trans. problem...help!
    Davenport, IA
    Quote Originally Posted by wickedintent79 View Post
    TCC stuck on.. ick.
    Delay in shift or "Long Shift" ??
    Sounds like you got 4t65E Blues...
  15. #15 Re: Strange Trans. problem...help!
    Apr 2009
    I have a 4t65e in a 07 GP GT. When I slow down to make a turn, and I notice it more on right turns, as I begin to accellerate out of the turn the shifting feels sticky thats the only way I can describe it. It seems to shift hard. I would'nt say its really slipping though cause my RPMs aren't flying up, or maybe its so slight I don't feel it. Anyway anyone ever experience this? Is this an example of factory shift characteristics or is something lurking for the future with this tranny.
  16. #16 Re: Strange Trans. problem...help!
    Missouri
    Well, I took it to Goodyear, and they said NOT motor mounts. They said if it were that, it wouldn't shake and shimmy, it would just "clunk" and stay in that position until the torque was released. Makes sense. I'm about to give up trying to find the problem because it sounds like its gonna be expensive to fix, and I'm not gonna dump 2500.00 bucks into a car thats worth.... you guessed it. 2500.00 bucks....
  1. Strange interior electrical/light problem
    By frozenlead in forum Audio, Security & Visual Electronics
    Last Post: 08-13-2009, 01:04 AM
  2. Trans problem
    By Pontiac99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-23-2009, 01:00 PM
  3. Strange car problem, but not as bad as I initially thought
    By Warhellride in forum Off Topic Discussion
    Last Post: 02-04-2009, 09:40 PM
  4. trans problem in a 00 gtp
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 05:16 PM
  5. 98 GT Trans Problem
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-14-2008, 09:47 PM
