Getting tripple edged soon andwant to run amsoil in the trans any suggestions?
I'd use what Trannyman himself suggests for his trannies. Way better than any Amsoil stuff...
I have heard good things and bad things about that tranny fluid. I would use what trannyman suggests. I think it is Dex6 with some other additive
I would also uses what he gives you, he knows his trannies and what works best in them.............fwiw, I do have a stock trans and use amsoil in mine. If my tranny does die, I will get a Triple Edge Performance Transmission and use his mix. In the end it is up to you though........
