Thread: I'm Stupid Please Help
Results 1 to 10 of 10
  1. #1 Re: I'm Stupid Please Help
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Here is a thread that is in the HOW-TO section that shows Transgo shift kit instructions. You will follow everything to put it back together aside the Transgo springs and spacers which are not used from the factory. You will simply have two larger diameter springs on the bottom side of the accumulator pistons and they are both the same. Make sure you use the correct piston in the correct bore as the top side smaller spring is larger for the 2-3 side which is noted in this writeup. It sounds to me like you may have taking the tubes out of the accumulator assembly and put the two small tubes back in reverse order so definately compare the pics I have with what you have on your car. It is also important to properly torque all of the bolts or you can have cross leaks or warp the parts which also causes cross leaks. If you reused the original gasket plate that can also cause leaks and it is not something I suggest trying to reuse because any leaks in this area will cause low pressure which will cause slippage.
    Here is the link with the writeup
    http://www.grandprixforums.net/shift_kit.php
  2. #2 Re: I'm Stupid Please Help
    Apr 2009
    MN
    Also I did put the two smaller tubes in wrong . . .*sigh* much to learn I still have
  3. #3 Re: I'm Stupid Please Help
    Fort Wayne, IN
    I dont have any pics of the other servo/piston assembly, which is the coast band apply servo. My next trans build I will try to snap a few pics and post them up. There is really only one way it goes together
  4. #4 Re: I'm Stupid Please Help
    Wausau, WI
    Quote Originally Posted by Snake View Post
    Thank You Yoda.........
  5. #5 Re: I'm Stupid Please Help
    GT Level Member tylerbinski's Avatar
    Canada
    Trannyman,,,, what kind of books did you write?
  1. stupid rice
    By keenan00gtp in forum Track Sessions and Kills
    Last Post: 03-02-2009, 08:46 PM
  2. How stupid are people?
    By Street Wolf in forum The Rant Forum
    Last Post: 11-23-2008, 10:58 PM
  3. Stupid Mustang
    By Freebeer187 in forum Off Topic Discussion
    Last Post: 11-04-2008, 07:21 PM
  4. stupid is as stupid does
    By gtman98 in forum Off Topic Discussion
    Last Post: 11-02-2008, 01:19 PM
  5. Stupid youtubers...
    By bentendo92 in forum Off Topic Discussion
    Last Post: 08-04-2008, 02:51 AM
