I have 98 Gtp with 125k miles on it. I got the car a year ago and it has always had a wierd shift... 1st and second are fine but when shifting to 3rd i need to take the car all the way up to 2800 rpm and it then shift into what im guessing is 4th because there are no more shifts after that. Rpm go down to about 1800 rpms...(note: when put under a lot of load on the highway like going up a long hill if i went down to about 45 mph it would down**** to 2nd gear but not shift back until i got off the highway and went slow for a good while) it was running fine like this for over a year, about a month ago i added soom metal lube now it has a slight shudder in 2nd and a nasty one in "4th" special between 55 and 70 mph.. above that it doesnt bother much unlees put under heavy load.. to me it seems as iff the tcc is stuck to the 3rd gear and after the metal lube its trying to separate and work how it should.. any help please planning on an tranny oil and filter change soon(note: it gives a P0741 code... tcc stuck off i think???)
