Thread: Tuner Changes for TCC Lock/Unlock Issue
Results 1 to 6 of 6
  1. #1 Re: Tuner Changes for TCC Lock/Unlock Issue
    Outer Space
    Thanks Dave, I'll give that a shot. It appears to do this more on an incline than on flat ground.
    EDIT:I see the table, but my values in TCC_apply_2nd_Normal, TCC_Apply_2nd_Perf, is all at the max 255. However TCC_Apply_2nd_Hot is not maxed out.. I notice it on the 1-2 shift going uphill... Should I change the HOT values?
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: Tuner Changes for TCC Lock/Unlock Issue
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    You shouldnt have to worry about the hot tables as I believe the pcm doesn enable HOT mode until you hit the 235-250 deg F range for trans temps. I havent seen this parameter to be adjustable yet with any of the tuners but it should be in that ballpark. Are the tables you are showing just MPH tables or apply% tables? I am not very familiar with the powertuner as I use HPT and they have specific minimum and maximum TCC apply duty cycle charts and that is what you need to adjust is the minimum apply duty cycle to help raise the apply pressure a bit to help overcome your problem.
  1. GM radio unlock procedures
    By Swash in forum How To Write-Ups/Tech Tips
    Last Post: 08-07-2012, 11:15 PM
  2. Question: Tranny Torque Converter lock/unlock issue
    By Lawngoose in forum General Tech Discussion
    Last Post: 05-31-2009, 09:54 PM
  3. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
  4. Increasing lock/unlock wirless strength
    By Freebeer187 in forum General Tech Discussion
    Last Post: 09-05-2008, 11:37 PM
  5. Trunk Switch/ Door Unlock and Lock
    By mainecrab in forum General Tech Discussion
    Last Post: 06-02-2008, 08:58 PM
