Thread: tranny swap
Results 1 to 11 of 11
  1. #1 tranny swap
    Nov 2008
    Minden
    will a 4T65E-HD tranny from a 98 GTP go into a 00 GT and if so how?
  2. #2 Re: tranny swap
    Barksdale AFB, LA
    You'd need to swap the torque converters and get the passenger side axle from an HD. Cooler line fittings may be different. You will also have to get your PCM reprogrammed for the different final drive ratio.
    2009 Subaru Impreza WRX STI
  3. #3 Re: tranny swap
    Not to mention that you might want to try to keep the 3.29's from your GT tranny...
    I can't fathom 2.93's on a N/A car...yikes.
  4. #4 Re: tranny swap
    Nov 2008
    Minden
    i guess the upside is that i have a complete parts car that i can swap everything i need from one to the other
  5. #5 Re: tranny swap
    Barksdale AFB, LA
    Well, for the gearing if you want to keep your 3.29 gears (which would keep you from needing PCM reprogramming) you'll need to disassemble parts of the trans to get to the chains and sprockets. They would need to be swapped from your current trans to the HD. Otherwise you could get new ones.
  6. #6 Re: tranny swap
    SE Level Member crazyGPlover's Avatar
    Springfield, MA
    i just swapped my 4T65-E for the 4T65-E HD and let me tell you its the best thing i could have done. my differential actually had blown up in my GT because of one small roll pin the broke to hold the gears in place. blew the thing to pieces. i bought the GTP trans but could not use the diff because i needed the passenger side HD axle. i took the GTP differential to a machine shop to have another hole drilled in to have another roll pin put in so i wont have to worry so much about that one weak spot in the transmission. got the new axle and installed it. also, if you can upgrade the steels and clutches to the GTP size so you can use the GTP sprag gear. much stronger and is a performance part already.
  7. #7 Re: tranny swap
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by crazyGPlover View Post
    Nope, there's no difference at all with the clutches or the sprag. The only difference between the HD and non-HD transmissions is the diff/cover/output shaft, and they put different gearing on the input side. Not only that, I believe the pinion shaft and spider gears that cause most diff failures are the same between the two (someone please correct me if I'm wrong on that), so the differences between the HD and non-HD are negligible. The roll pin most often breaks because one of the spider gears catches on the pinion shaft and rotates it, breaking the pin, and that should only happen if one wheel is moving significantly faster than the other. One wheel peels = death for either trans.
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: tranny swap
    Springfield, MA
    well i did use an 04 gtp trans to put into my 02 gt. the sprag is different, and the clutches are too, the teeth are larger in the gtp compaired to the gt. and the spider gears are much larger in the gtp differential also. trust me i had just done the swap a week ago, and i compaired the 2 diferentials, along with other parts to see what i could use and what i couldnt.
  9. #9 Re: tranny swap
    Barksdale AFB, LA
    I have those parts, and my transmission isn't an HD. It's just changes that came out in 03. They don't really help with anything anyway, as the transmission still fails in the same ways it always did.
    The stronger diff only helps when doing burnouts or hard launches. Other than that my non-HD diff has been taking the punishment of the blower just fine. HD transmissions are not anything special. In fact, I'd rather have a non-HD with the HD diff so you get 3.29 gears.
  10. #10 Re: tranny swap
    QCA, IA
    The sprag changed in 03 on all of the transmissions, it has nothing to do with HD vs non-HD. Dave has also said many times that there's no advantage to the diode type vs the pawl type sprag, and it only affected the input clutches.
    You could be right on the size of the spider gears, but I still don't see how it would change the problem. The lack of lubrication for them makes them seize to the pinion shaft and rotate it, sheering the roll pin.
  11. #11 Re: tranny swap
    Banned - Busted For Scamming
    Feb 2009
    ^open diffs suck.
  1. pcm help with tranny swap
    By ddyke2000 in forum PCM Tuning
    Last Post: 05-03-2009, 01:41 PM
  2. Tranny swap
    By kbradley in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2009, 07:45 AM
  3. Help!! Tranny Swap Engine ''Refresh''
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-10-2008, 12:04 PM
  4. Getting ready to swap the tranny chain...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2008, 10:49 AM
  5. DIC swap
    By chrissbee77 in forum General Tech Discussion
    Last Post: 02-26-2008, 06:02 PM
