Quote Originally Posted by 19SE92 View Post
My trans was orginaly built for dex 2 from gm. And before I stick something in it the bottle has to say its compatible with dex 2 and dex 3. And the only mix I use is when I do my trans or any trans is one bottle of lucas trans fix and dex 3 fluid. If someone has a bottle of 6 in there hand can u tell me if it says it will work with a dex 2 trans
And again.......I quote.
DEXRON®-VI can be used in any proportion in past model vehicles equipped with an automatic transmission/transaxle in place of DEXRON®-III (i.e. topping off the fluid in the event of a repair or fluid change). DEXRON®-VI is also compatible with any former version of DEXRON® for use in automatic transmissions/transaxles.
