My tranny has been acting flakey for the past few weeks and tonight it went nuts The shifting is ALL jacked up now. Here is what I found out about the P0757 error code. The information came from a LS1 GTO forum, but it explains my problems to a T! Now I have to figure out what needs to be done to correct the problem.
Oh Dave...................................
Check the TSB's: LS1GTO.com Forums - Open track day 5
DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris) #01-07-30-038B - (Jan 26, 2004)
with 4L60-E/4L65-E Automatic Transmission (RPOs M30/M32)
Condition
Some customers may comment on any of the following conditions:
The SES lamp is illuminated.
No 3rd and 4th gear.
The transmission does not shift correctly.
The transmission feels like it shifts to Neutral or a loss of drive occurs.
The vehicle free wheels above 48 km/h (30 mph). High RPM needed to overcome the free wheeling.
Cause
The most likely cause is chips or debris plugging the bleed orifice of the 2-3 shift solenoid. This will cause the transmission to stay in 2nd gear when 3rd gear is commanded and return to 1st gear when 4th gear is commanded.
DTC P0757 may also be set if the 2-3 shift valve or 2-3 shuttle valve were stuck, restricted and/or hung-up in its bore.
Correction
Inspect / Clean the 2-3 shift valve, the 2-3 shuttle valve and the valve bore of debris / metal chips.
Inspect / Clean the 2-3 shift solenoid opening of debris / metal chips. While inspecting the 2-3 shift solenoid, look for a screen over the solenoid opening. If the solenoid DOES NOT have a screen, replace the solenoid with P/N 10478131 that does have a screen over the solenoid opening.
Refer to the appropriate Service Manual for additional diagnostic information and service procedures.
Parts Information
Part Number
Description
Qty
10478131
Valve, 2-3 Shift Solenoid
Parts are currently available from GMSPO.
