ok, motor and trans are out, the input shaft broke PERFECTLY clean along the o ring groove
now the input shaft i got off my forum member does not have the o rings on it, where can i get rings for this shaft?
can i use stock ones from a stock input shaft?
and while im replacing the shaft and chains, is there anything else i will need to replace while im in there? side cover gasket should be fine i hear?
and what about torque specs?
thanks!
