Thread: Tranny swap
Results 1 to 5 of 5
  1. #1 Tranny swap
    Nov 2008
    Minden
    Hey guys
    i have a 00 GT with no over drive and i was given a 97 SE with a 3.8 with a good tranny in it now is there any way to put the tranny from the 97 into my 00?
    Thanks in advance
  2. #2 Re: Tranny swap
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Not easily, no. The 97 SE is going to be a 4T60, not a 4T65E.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Tranny swap
    Apr 2009
    Georgia
    I am actually doing the same swap right now and I have ran into a few minor problems the torque converter does not mount to the fly wheel, and you will have to reprogram your computer because of the difference in the gear ratio.
  4. #4 Re: Tranny swap
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    As mentioned above the 97 SE has a 4T60E and will not work with the 00 pcm. The 4T60E uses a completely different TCC arrangement and also does not have an input speed sensor or pressure control solenoid. If you had a 97 GTP trans then tuning would allow you to use it, but the SE and GT used a 4T60E trans that is not compatable without a handful of wiring and earlier pcm and isnt worth the trouble
  5. #5 Re: Tranny swap
    Barksdale AFB, LA
    Quote Originally Posted by ddyke2000 View Post
    That's because you picked up a 4T65E-HD to replace the normal 4T65E in your car. They use different size torque converters and different gear ratios. FWIW, you will also need a different passenger side axle due to the different differential on the HD transmission.
    Like I told you, easier to sell that transmission and go find the right one.
    2009 Subaru Impreza WRX STI
  1. top swap
    By jrgoleman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-22-2009, 04:24 PM
  2. Help!! Tranny Swap Engine ''Refresh''
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-10-2008, 12:04 PM
  3. Top end swap???
    By Randy_W in forum General Tech Discussion
    Last Post: 06-01-2008, 06:24 PM
  4. Getting ready to swap the tranny chain...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2008, 10:49 AM
  5. DIC swap
    By chrissbee77 in forum General Tech Discussion
    Last Post: 02-26-2008, 06:02 PM
