Thread: Malfunction Question
Results 1 to 3 of 3
  1. #1 Malfunction Question
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    I have a rebuilt transmission with less than 10K miles on it. It's starting to not want to shift into fourth, and shudders when it does.
    I'm not going to have to fix it myself, it's under warranty, but I'm curious what the cause could be, to a) verify what the shop tells me, and b) to know what I'm going to have to deal with when the warranty's over.
  2. #2 Re: Malfunction Question
    St. Louis
    Not a huge 4t65e expert but in dealing with my own the not wanting to shift into overdrive sounds like a worn 4th clutch hub. Which is strange since the later years had the hardened shaft to eliminate this issue.
    Never had one shudder but that symptom to me sounds like a torque converter lockup issue. On a full rebuild you should have a new/reman torque converter in it. Hopefully they didn't reinstall your old one.
  3. #3 Re: Malfunction Question
    Jul 2016
    Brevard County, FL
    Not wanting to name the shop at this point, but they do promise that the torque converter is remanufactured on their website. I guess I'll find out for sure next week.
  1. P0650-Malfunction Indicator Lamp (MIL) Control Circuit Malfunction.
    By curtisrossiger in forum Introductions/Noob Questions
    Last Post: 08-31-2020, 11:38 PM
  2. DOD Malfunction
    By BuddhaRaider in forum 5.3L V8 (LS4)
    Last Post: 05-27-2018, 08:59 PM
  3. 02 3.8l maf malfunction ?
    By GERRY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2015, 05:32 PM
  4. heater malfunction
    By randyp in forum Introductions/Noob Questions
    Last Post: 12-31-2011, 05:20 PM
  5. Window malfunction
    By dagger in forum General Tech Discussion
    Last Post: 04-15-2010, 07:47 AM
