Thread: Rebuilding Valve Body
Results 1 to 3 of 3
  1. #1 Rebuilding Valve Body
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    Has anyone installed the Sonnax valve kit 84754-43k? I looked up the instructions on Sonnax website and it mentions this one part about using a drill bit to bore out the end of one of the bores but it is very vague. Could anyone help clear up how this is installed. The whole reason I'm rebuilding the transmission is due to TCC shudder. So if this kit will help id like to install it. Plus I already have it.
  2. #2 Re: Rebuilding Valve Body
    Kemmerer, Wyoming
    if you don't get a reply on here, I would recommend asking Dave at TEP. you can email him.
    Contact Us
  3. #3 Re: Rebuilding Valve Body
    Mar 2014
    Tucson
    Quote Originally Posted by chrisrexmandie View Post
    it mentions this one part about using a drill bit to bore out the end of one of the bores...
    I have not personally installed this kit, but I have some transmission experience. After reading the instructions, it looks like they tell you to use that drill just to chamfer the leading edge of that valve bore. To kind of "funnel" that sealing ring into the bore. I would do that by hand. Not with a power drill.
    The edges on some of those bores are razor sharp. If you jam that valve into that bore and the PTFE seal is sticking out even a little, you will shave it right off. This is also the reason for the 45 minute paper tube trick. Trying to squeeze that seal into the valve.
  1. 4t65E valve body bolts
    By 3repete in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-26-2017, 04:39 PM
  2. 04 Grand Prix transmission valve body?
    By Lovemyprix23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-01-2016, 01:09 PM
  3. WTB or Trade for TapShift valve body
    By Suaveat69 in forum Wanted To Buy - Parts
    Last Post: 03-09-2015, 12:47 AM
  4. valve body replacement
    By Jakescoots in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-20-2011, 07:18 AM
  5. valve body
    By jaygtp98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-05-2011, 06:57 PM
