Thread: Transmission works when cool.
Results 1 to 4 of 4
  1. #1 Transmission works when cool.
    Oct 2019
    Geneva, Ohio
    I have an 08 Base with 270,000 miles. Friday evening I was driving in town, and the transmission lost drive. No reverse,1,2, or 3. Shut it off for a few minutes, restarted, and it worked fine, just not long. Have not a lot of research yet. Any suggestions? It sure feels like an electrical issue,
  2. #2 Re: Transmission works when cool.
    Mar 2014
    Tucson
    Many times (but not always) that is a symptom of a clogged filter.
    After running for a bit, the filter will suck up a bunch of crud and clog. Turn off engine, trans stops pumping fluid, crud "falls" out of the filter. Repeat cycle.
    Especially if it's not throwing any codes.
    When was it last serviced?
  3. #3 Re: Transmission works when cool.
    Oct 2019
    Geneva, Ohio
    Car was given to me so I don't. As so as its warm enough, I'll check. I've been fixing as it breaks. Thanks for the help.
  4. #4 Re: Transmission works when cool.
    Oct 2019
    Geneva, Ohio
    Thank You. Car was given to me. I'm fixing as it breaks
  1. Transmission wont downshift works manually???
    By james125 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-12-2016, 09:47 PM
  2. Only one HID works
    By TeacherCreature in forum General Tech Discussion
    Last Post: 07-04-2013, 04:37 PM
  3. How Axe really works....
    Last Post: 07-30-2011, 11:32 PM
  4. 99 GTP A/C works great, then stops, then works great again
    By stotzbotz in forum General Tech Discussion
    Last Post: 09-27-2009, 02:39 PM
  5. It Works!!!
    By 02BlueGT in forum PCM Tuning
    Last Post: 08-31-2008, 01:02 AM
