Thread: 4t65e hard to move after 4th hub replacement
Results 1 to 3 of 3
  1. #1 4t65e hard to move after 4th hub replacement
    Jun 2020
    VA
    I have a 2000 Impala 3.8 with a 4t65e 189,000 miles. Car had no 4th gear so I replaced the 4th gear hub, 4th gear clutches, all solenoids, and put a shift kit in.
    After putting fluid in the car I need to give it alot of gas just to move in any gear, the level is good.
    Anyone know what would cause this?
    Wrong solenoids maybe?
  2. #2 Re: 4t65e hard to move after 4th hub replacement
    Maybe an internal leak? Did you use fresh channel plate gaskets?
  3. #3 Re: 4t65e hard to move after 4th hub replacement
    Jun 2020
    VA
    I did replace the channel gaskets, maybe one got pinched. I'll check that out thanks. When I turn the car off I can hear fluid flowing for a few seconds so Im thinking this might be it.
  1. 4T65E Hard Shift-Solution
    By jbamonte in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-23-2023, 08:14 PM
  2. 4t65e quick fix to hard shifting
    By bluesfan4life1955 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2017, 07:00 PM
  3. 4t65e transmission hard 1 to 2 shift.
    By RM686 in forum General Grand Prix Discussion
    Last Post: 10-12-2015, 04:28 PM
  4. Hard shifting 4T65E in '99 GTP
    By SnowDrift in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2014, 12:08 AM
  5. how hard would it be to move a motor?
    By Poil336 in forum Off Topic Discussion
    Last Post: 06-30-2010, 10:35 PM
