Thread: installing trans tc question
Results 1 to 16 of 16
  1. #1 Re: installing trans tc question
    Mar 2014
    Tucson
    Quote Originally Posted by blakephxaz View Post
    can u take the transmission off and just leave the tc attached to the fly wheel and leave it there and when done just install the transmission back on or will that cause a problem
    For disassembly, sure you could leave the TC on the flexplate. For reassembly, you would have to install the TC into the trans first.
    what does that mean click it 3 times
    The TC locks on to 3 splines shafts. Each one will allow the TC further into the transmission. 3 steps or clunks. It's a good "rule of thumb" but the best way to know it's all the way seated is to measure the distance from the bellhousing to the mounting tabs on the TC. IIRC, it should be right around an inch in.
    Edit: I type too slow. Sounds like a pump problem.
    If you want a real rebuild, take a drive about two hours south.
  1. Question about installing DIC in 02 GP GT
    By Andrewh05 in forum General Grand Prix Discussion
    Last Post: 07-02-2015, 08:18 PM
  2. Problem after installing used trans.
    By juskev25 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-27-2014, 11:16 PM
  3. trans question
    By 06PONTGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2012, 04:21 PM
  4. Installing Cam - Question About Timing Chain
    By LapeerGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2012, 03:14 PM
  5. Trans question
    By davidl25 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2009, 07:27 PM
