Thread: Tranny finally broke, what else to do while replacing?
Results 1 to 8 of 8
  1. #1 Tranny finally broke, what else to do while replacing?
    SE Level Member dirtyape's Avatar
    Dec 2014
    Lomita,Ca
    The trans on my 97 gtp lost the forward band this week at a little over 204k miles. Was still able to limp around in 2nd and get to the tranny shop and back home. Tried to be upset but at 204k miles, how can I be?
    Talked to the guys at TEP. Went over my mods and have a hps1 in the works. It will be nice to know that I have a tranny that I don't have to baby anymore. Not that I'm gonna be racing around, but just piece of mind.
    I have new poly lower motor and trans mounts on the way from ZZP. I know that the tranny seal and main engine seal, which started dripping 4-5k ago, should be done since everything is going to be apart.
    My question for the board is, what else to do while pulling the old tranny and putting in the new one?
    also
    Is anyone in the torrance ca, area interested in my old tranny? Should i craigslist it or put it on the board or both?
  2. #2 Re: Tranny finally broke, what else to do while replacing?
    SE Level Member Moozery's Avatar
    Apr 2016
    Ontario
    Quote Originally Posted by dirtyape View Post
    I think you should be able to get a core refund at TEP for your old transmission, just as another option.
    http://www.tripleedgeperformance.com...anty_Info.html
    Pre-Production 2004 GP GTP Comp G / 91,000mi / TransGo Shift Kit, Spectre Open Cone, 180 Tstat, AL605's, ZZP 3" catted DP, ZZP front PLog, Intense PCM, GMPP Sway Bar
    Access Old "How-To" Links
  3. #3 Re: Tranny finally broke, what else to do while replacing?
    May 2008
    Schuyler, NE
    Listing your mods might help.
  4. #4 Re: Tranny finally broke, what else to do while replacing?
    Dec 2014
    Lomita,Ca
    I have a 97 gtp, with slp intake and hood, tog headers with better flowing resonator and ubend delete, zzp larger radiator, zzp intercooler, 3.4 pulley, zzp upper motor and dogbone poly mounts, prj fuel rails and plug wires, custom tune on the pcm, rat suspension kit, bear brake kit front/rear and many other things but not things that would matter to a tranny swap.
    I just did new ac delco lca's with the moog problem solver bearings and moog endlinks.
    I have a month before the trans is here so I am trying to make sure and do the things that should be done when the drive train is apart.
    I could send the tranny back for the core charge, but its $200 shipping to get a $300 core charge back. $100 isn't anything to sneeze at, but if i could sell it locally for 1-200 that would be great.
  5. #5 Re: Tranny finally broke, what else to do while replacing?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Do the rear Main seal, maybe the knock sensor since its easy access. If you have the cradle dropped, new subframe bushings and oil pan gasket if needed.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  6. #6 Re: Tranny finally broke, what else to do while replacing?
    Mar 2017
    Internet
    this was going to be my list
    Quote Originally Posted by rickisrad View Post
  7. #7 Re: Tranny finally broke, what else to do while replacing?
    Dec 2014
    Lomita,Ca
    Thanks guys, this is the kind of info I need.
    is this the subframe bushing stuff?
    http://www.gmpartsdirect.com/auto-parts/1997/pontiac/grand-prix/gtp-trim/3-8l-v6-gas-engine/front-suspension-cat/suspension-mounting-scat
  8. #8 Re: Tranny finally broke, what else to do while replacing?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    yes # 5 and 3. two of each. search the part numbers on ebay you may find them cheaper. I bought the comp G rear bushings off of ebay
    you probably will not need the washers and bolts. those you should be able to re-use. rock auto has the front kit by Dorman.
  1. ughhh tranny finally bit me!
    By paedbo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-29-2014, 05:48 PM
  2. Finally broke into the 12's.
    By mkyota1 in forum Track Sessions and Kills
    Last Post: 12-01-2013, 04:17 PM
  3. Replies: 4
    Last Post: 11-22-2013, 03:49 PM
  4. Considering replacing tranny
    By puma1297 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-28-2011, 08:29 AM
  5. tranny broke
    By justin usher in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2009, 04:13 PM
