Thread: 4t65e shift solenoids help please
Results 1 to 3 of 3
  1. #1 4t65e shift solenoids help please
    May 2017
    poole dorset uk
    Hi all sorry for this silly question but I recently rebuilt my 4t65e tranny and I think I have managed to swap 1 2 shift solenoid with 3 4 it still drives but at 20mph it's around 4k if I man shift 1 through 4 3 and 4 seem to be higher gear than 1 2 has anyone made the same mistake? Did they notice similer issues? Any and all help will be appreciated many thanks in advance
  2. #2 Re: 4t65e shift solenoids help please
    SE Level Member Transman304's Avatar
    Jan 2017
    West Virginia
    Shift solenoids are the same in either location. Sounds like it is in limp mode. Everything plugged in?
    Brad
    "If you can't fix it with a hammer you have an electrical problem"
    Like us on Facebook @ " Otto Matics"
  3. #3 Re: 4t65e shift solenoids help please
    May 2017
    poole dorset uk
    Thanks for everyone's help I believe I've solved the issue now my spacer plate is bonded and master rebuild kit came with gaskets which I wrongly assumed you put it with spacer plate so guess it's time to strip it all down again
  1. need trans advice - new solenoids or shift kit (or both)?
    By mjgrantham2003 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-23-2016, 02:45 PM
  2. 4t65e Shift Kit
    By Jonarin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2015, 03:23 AM
  3. Should I put in a shift kit and change all 5 solenoids?
    By Sobie in forum Introductions/Noob Questions
    Last Post: 01-26-2013, 04:49 PM
  4. Shift Solenoids
    By txturbo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2010, 05:55 AM
  5. Does the trans need to be dropped to swap out shift solenoids?
    By bminior in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-08-2008, 08:59 AM
