Thread: Trans won't shift -- Disconnect battery and it's fixed?
Results 1 to 8 of 8
  1. #1 Trans won't shift -- Disconnect battery and it's fixed?
    Mar 2016
    MD
    Car has been sitting for a few weeks. Drove fine before being parked.
    Reconnect battery, pull out of parking spot up a hill, and about 10 ft out of the spot, car won't move. No reverse, no 1st 2nd D. Push car back in to the spot.
    Disconnect battery, reconnect, all is well...took car out for a drive, no issues.
    Seems like some sort of electrical issue to me. Anything I should be checking?
  2. #2 Re: Trans won't shift -- Disconnect battery and it's fixed?
    SE Level Member Transman304's Avatar
    Jan 2017
    West Virginia
    That is something I have never experienced or had a customer complaint like that. That transmission will still move in 3rd gear with trans unplugged. Fluid level ok? That's just bizarre I'm curious to see if someone has had this happen or have a explanation.
    Brad
    "If you can't fix it with a hammer you have an electrical problem"
    Like us on Facebook @ " Otto Matics"
  3. #3 Re: Trans won't shift -- Disconnect battery and it's fixed?
    unhooking the battery reset the pcm, this will make things work again till it trips what ever code / electronic issue again. should have scanned it for codes before shutting it off. might of have a pending code. keep a scanner handy should it act up again.
  4. #4 Re: Trans won't shift -- Disconnect battery and it's fixed?
    Mar 2016
    MD
    There were no active codes but I didn't think to look at scanner for pending.
    Very odd. Hopefully doesn't happen again
  5. #5 Re: Trans won't shift -- Disconnect battery and it's fixed?
    Mar 2016
    MD
    And fluid is good. Full, not burnt. No leaks
  6. #6 Re: Trans won't shift -- Disconnect battery and it's fixed?
    May 2008
    Schuyler, NE
    Any strange noises when it would not move?
  7. #7 Re: Trans won't shift -- Disconnect battery and it's fixed?
    Mar 2016
    MD
    Nope. Drove it around 30mi today no issues....so odd
    I'm going to get it in the air this weekend and see if anything looks "off"
  8. #8 Re: Trans won't shift -- Disconnect battery and it's fixed?
    Mar 2017
    Internet
    With no power and unplugged. Like it was mentioned, you'd have 3rd.
    While I have never heard this one before....part of me is thinking, what electronically could do that...
    Maybe the pcs bled off too much pressure, hence no hydraulic pressure to engage the forward band. Resetting power either reset the pcm or unstuck the soleniod etc and did the trick. I'd chaulk it up to a single time technical difficulty if it doesn't seem to repeat itself
  1. ZZP Trans Pan + TransGo Shift kit
    By nos4blood70 in forum For Sale - Parts
    Last Post: 01-22-2015, 09:35 PM
  2. BNIB Trans-go shift kit
    By SnowFlake in forum For Sale - Parts
    Last Post: 04-18-2014, 09:22 AM
  3. 2000 gtp performance shift fixed! tips
    By invertverticalreverse in forum General Tech Discussion
    Last Post: 12-27-2010, 12:11 PM
  4. GTP Trans won't shift to 4th after hill
    By SliceTheRice in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-11-2010, 10:37 AM
  5. Trans does not want to shift out of 1st until warm
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2010, 11:45 AM
