Thread: 99 GTP (P0756 error code)
Page 4 of 4 FirstFirst ... 234
Results 61 to 75 of 75
  1. #61 Re: 99 GTP (P0756 error code)
    Mar 2014
    Tucson
    Usually just a resistance check with a DVOM.
    I don't remember the exact values. They're somewhere in the trans build thread in my sig. Or Google.
  2. #62 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Nevermind. A quick google search and 10 minutes later I had my answer. Got valve body apart. There was some metal flakes in it but other than that nothing. One of the plungers feels weak like it has a bad spring or something.
  3. #63 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Ok thanks. For some reason I didn't see this earlier.
  4. #64 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Ok guys big update time.
    When cleaning everything found a plugged up orifice on the spacer plate. Also, one of the screens on the spacer plate was plugged up. Everything cleaned out now. Valve body had a big chunk of something, thinking built up clutch material. Reassembling today, everything is quite clean and ready to go. If everything goes to plan i'll have all gears and be good as new (I can hope). Either way, i'm going to pickup a used transmission/engine saturday. What's the best rebuild kit for our transmissions? Wanting to build it up to stay mainly stock, maybe a 3.5 pulley drop tops. As long as it can handle wot.
    Again, thanks for all input!
  5. #65 Re: 99 GTP (P0756 error code)
    Mar 2014
    Tucson
    Quote Originally Posted by Revan365 View Post
    They're pretty much all the same. Minor differences in clutch material for some of the clutches, but most are Trans-Tek seal and gasket set, Raybestos steels and Borg-Warner clutches. For a mostly stock setup, a standard kit will be fine. The important thing is how you set it up.
    Do you have a Transtar nearby? That's my go to.
  6. #66 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Quote Originally Posted by BrandonHall10 View Post
    Sadly no. But good to know. I'd be putting in the used trans if this didn't work out and then rebuilding said trans that's in the car. As long as I could mash on the gas, some wot here and there I'll be ok.
  7. #67 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Great news. It shifts fine now!!
    F'ing shifter cable broke though. Not one thing its another.
  8. #68 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Shift cable is good again. Leaking transmission fluid from side cover, new gasket in 2 days. I just can't catch a break.
  9. #69 Re: 99 GTP (P0756 error code)
    SE Level Member Transman304's Avatar
    Jan 2017
    West Virginia
    Is it leaking where the Torx bolts are? If so may be a cracked side cover. Very easy to do when tightening down. Ask me how I know. Lol! Just double check so you don't put the new gasket on and still have a leak.
    Brad
    "If you can't fix it with a hammer you have an electrical problem"
    Like us on Facebook @ " Otto Matics"
  10. #70 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Quote Originally Posted by Transman304 View Post
    Yeah down at the bottom around the bolts. We simply tried to use the old brand new gasket but where it had fallen apart we used gasket maker to help seal it. The new one will be here tomorrow.
  11. #71 Re: 99 GTP (P0756 error code)
    Jan 2017
    West Virginia
    Good luck man!
    Brad
  12. #72 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Good luck man!
    Thanks! So close to being done.
  13. #73 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Found me a good parts car as well! Guess this makes up for all of my bad luck. Some guy selling it for $500
  14. #74 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Parts car is trash. Oh well. Good news is that it turns out my car is running a 3.5 pully and a 3 inch down pipe. Yay
  15. #75 Re: 99 GTP (P0756 error code)
    Dec 2016
    United States
    Well, after one month and 3 tear downs everything works. It shifts gears pretty good but it shifts hard 2-3 around 50. Revs up to almost 3.5k so I think its running a custom tune. Has a stupid p0401 code now which is the egr valve? Anyway, thanks for all of the help. I'll put a summary of what all we did to fix it up in the first post to help future viewers.
  1. error code troubles
    By thedudeSE in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-23-2011, 11:16 AM
  2. Error Code P1404
    By Beaver6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2011, 07:36 PM
  3. error code
    By fran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 06:28 PM
  4. error code p0650
    By IrishNation24 in forum General Tech Discussion
    Last Post: 01-16-2010, 10:50 AM
  5. DTC code error
    By carlos Hidalgo in forum General Tech Discussion
    Last Post: 08-11-2009, 08:35 PM
