Allright seeing as some of you are looking for some crazy mods, i've been thinking about trying to modify bushings and washers to bearings, and i succesfully came up with two in a 4l60e trans, but now i have a 4t60e and it's time to get back to the drawing board.
Why change bushings and thrust washers to bearings?? Well...I can't prove it, but it is said that if you convert all the thrust washers in a c6 transmission to bearings you can salvage 15 hp to the wheels!!! I actually believe this because if you've ever taken apart a hondamatic you'd see how much resistence is taken off with barrel bearings instead of bushings.
