Thread: Changing internal gearing? (not final drive)
Results 1 to 17 of 17
  1. #1 Re: Changing internal gearing? (not final drive)
    Yup
  2. #2 Re: Changing internal gearing? (not final drive)
    Are the gear ratio's in a 4t60 different? Im not sure if you would be able to change the parts and make everyting still fit and work the way it should. Its been a long time since i was in autotrans class so hard to remember everything.
  3. #3 Re: Changing internal gearing? (not final drive)
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Quote Originally Posted by my97gtp View Post
    That is part of the reason I was going to go to school one extra year. I planned on taking a year of auto classes (transmissions being one of the classes). But after thinking about it, it just wouldn't have been worth the extra money.
    Ron why don't you just put some bigger tires on your car
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  4. #4 Re: Changing internal gearing? (not final drive)
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    And you think YOU have it bad lol. The 4L60E transmission has a 3.06 first gear then jumps waaaayyy down to 1.6ish for 2nd! Thats ok, the M90 cars make so much torque everywhere it doesnt bother me, especially since RWD cars hook up My cutlass cuts low 1.6 60' times on drag radials in full street trim, with a 2200 rpm torque converter. After the car comes off the line its a very small powerband, between 4950 and 6800 all the way down the track. 1st gear is basically a lever to move the car. The above with was 3.73 gears. I was going to stick 4.10s back in but since I am putting a turbo on the car I will never go through the traps in 3rd with that or the 3.73s as i crossed the line at 6K rpm in 3rd with the 3.73s. The car has 3.23 gears in it now so I should be safe for a while. Ron back to your wanting to change gear ratios, I dont know of anyone that has done this with any fwd GM trans but for other rwd old transmissions there are kits but VERY expensive. Remember in changing ANY of the gearing you altering every gear ratio 1st - Reverse. If its a strip only car then I would go with a higher stall converter and run 3.29 or 3.69 gears to let the engine sit higher in the powerband. Traction is always the problem with these cars so it makes it hard to have a car that does everything everywhere.
  5. #5 Re: Changing internal gearing? (not final drive)
    Oklahoma
    Quote Originally Posted by Trannyman95 View Post
    Dont you love having a car that you can say that about? I do. I mean, its not like a Geo Metro or something, LOL.
  6. #6 Re: Changing internal gearing? (not final drive)
    Fort Wayne, IN
    Well Scotty thats why I put the engine in a rwd car lol.
  7. #7 Re: Changing internal gearing? (not final drive)
    Hoping that wouldn't be the answer...
    Do you know the ratios for the 4L80? Or the available final drives are?
  8. #8 Re: Changing internal gearing? (not final drive)
    Fort Wayne, IN
    4L80E ratios are
    1st-2.48
    2nd-1.48
    3rd-1.00
    4th-.75
    4T80E ratios are
    1st-2.96
    2nd-1.63
    3rd-1.00
    4th-.68
    4T60/65E ratios are
    1st-2.92
    2nd-1.57
    3rd-1.00
    4th-.71
    There are a few different final drives for the 4T60/65E that will work in these transmissions BUT becaues the gears are of different tooth count and none of the other ratios are HD diffs I dont think the gearing changes between the two as the diff case is different sized for the gearing. IIRC the choices are 3.29 as the HD diff is, 3.05, and 2.86 for NON HD
  9. #9 Re: Changing internal gearing? (not final drive)
    Wow, the 4L80E looks good for the gearing. Will the internals swap to the transverse model? If I do a trans, looks like a promising set-up if the final drive selection is right.
  1. Drive Belt Idler Pulley Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 06-20-2014, 05:07 PM
  2. Drive Belt Replacement [*]
    Last Post: 05-24-2009, 05:44 PM
  3. My almost certain final moment on ClubGP
    Last Post: 01-30-2008, 12:18 PM
  4. Drive Belt Tensioner Replacement [*]
    Last Post: 01-03-2008, 10:54 PM
  5. Final step of tinting my tails need a lil help please
    Last Post: 12-27-2007, 08:44 AM
