Hoping someone can help. I have a 2001 gtp, the PRND321 on the cluster is not lighting up at all in any gear.
Any ideas ?
I've been looking through the wires in the console and haven't found anything broken
Thanks
Any ideas ?
Thanks
there are 7 Leds on the cluster, its on a separate circuit board from the rest of the cluster everything looks ok
2001 GTP, There are out in the dash all factory
the light bulbs went out. take the trim off around the dash and cluster, then unscrew the cluster, theres a plug on the back un hook it, then take the bulbs out, they just turn in and out on a thumb screw deal thing.
ok thanks
If you take out Thoses two screws where you have circled there are 7 leds soldered in and none light up
they all went out at the same time
you can see in the picture where I'm talking about is a different color
I tried to resolder everything in there but still a no go
Well at least you know what to do now... JY hunting time.
im going with you dont have a led strip, its all light bulbs. and one or more are out. them plastic boards tend to fail, if you find a break along the paths there they sell a brush on paint like stuff to repair the board and fix the bad connection.
That's right no strip I don't have a strip
you lift up the circuit board and there are resistors and LEDs
I've looked for breaks and resoldered the resistors and still won't light up
ive pulled the consol apart and inspected the wires that run to the shifter and everything looks ok
Ive had it apart twice now and don't know what else to do
