Thread: Transmission Cooler Questions
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
  1. #1 Transmission Cooler Questions
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    So I recently bought a WIX transmission filter because I'm planning on changing the fluid and filter on Friday. I know my transmission already has a shudder issue only going from 1st to 2nd at high RPM and when the transmission is warm, but it hasn't done it recently. I just went to go check the fluid and found this:
    Yeah, basically black. Now I was recommended by a member on here about a product to add that will prevent slippage and shudders. This is what that product is: http://www.lubegard.com/~/C-230/Instant+Shudder+Fixx. I will be buying one of those, but after seeing how black my fluid was with clutch material, I'm having second thoughts about it. It's only gonna be a pan drop so it's not like all that fluid is gonna come out. But I don't know, is there anything else I should add in addition to the Lubegard product to prevent and slipping? If my transmission slips after this, it's bye bye to the top swap project. Thanks a bunch guys.
  2. #2 Re: Second Thoughts About Transmission Fluid Change
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Black fluid could be the cause of the shudder.
    Is that the original dex 3?
    Fresh dex 6 could help. Need someone more edumacated to respond about how to check for the metal flakes.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  3. #3 Re: Second Thoughts About Transmission Fluid Change
    Apr 2015
    Quote Originally Posted by EJOUIE View Post
    Yes, it's the original DEX III to my understanding. And I will not be using DEX VI since it's a thinner fluid and I need a thicker fluid to ensure nothing goes wrong.
  4. #4 Re: Second Thoughts About Transmission Fluid Change
    The fluid is still a brownish color, it's just the clutch material that likes to stick to the dipstick.
    Lube guard or some lucas can be used.
  5. #5 Re: Second Thoughts About Transmission Fluid Change
    Apr 2015
    If I can do both of those at the same time, I'll go that route. I didn't know that the clutch material stuck to the dipstick. That explains why the entire thing was black. I'll go ahead and change the fluid then. Thanks!
  6. #6 Re: Second Thoughts About Transmission Fluid Change
    Kemmerer, Wyoming
    I don't think I would bother with dex 6 because it costs a lot more, and the car was designed to be used with dexron 3.
  7. #7 Re: Second Thoughts About Transmission Fluid Change
    Buffalo
    Clean your dipstick first then re check the oil color.
    Dex3 is good for what you're doing
  8. #8 Re: Second Thoughts About Transmission Fluid Change
    Apr 2015
    Quote Originally Posted by CrazyGuy03 View Post
    Car's put away for the night. Going to be going to bed shortly anyways. I will do that tomorrow, thanks for the tip.
  9. #9 Re: Second Thoughts About Transmission Fluid Change
    Do not mix additives into the trans, you could cause more damage doing that. Some of those additives don't play nice together.
  10. #10 Re: Second Thoughts About Transmission Fluid Change
    Apr 2015
    Quote Originally Posted by Slick2500 View Post
    So which do you think I should put in?
    I'll probably give Lubegard or Lucas a call sometime and see what they say.
  11. #11 Re: Second Thoughts About Transmission Fluid Change
    SE Level Member Cruisin38's Avatar
    Sep 2015
    Northern Illinois
    My buddy was telling me the only trans product he ever noticed a difference with was Seafoam Trans Tune.
    He completely lost over drive and added a can of that.
    One day overdrive just came back and he never lost it again.
  12. #12 Re: Second Thoughts About Transmission Fluid Change
    Never heard of Lubeguard before, so I can not tell you anything about it. My 97 had ~155k miles on it when I got it with a bad trans, I dumped out all the old brown fluid and put in all new Dex III and a bottle of Lucas. The trans lost 4th gear at 181k miles. Idk if the Lucas helped or not but getting almost another 30k miles out of a bad trans isn't too bad.
  13. #13 Re: Second Thoughts About Transmission Fluid Change
    Apr 2015
    Nor dif I before I looked them up. And they seem very legit with a variety of products. But I'll still call them and see what they say about mixing them.
  14. #14 Re: Second Thoughts About Transmission Fluid Change
    Buffalo
    I hear that the newer trannies use gender fluid ....
  15. #15 Re: Second Thoughts About Transmission Fluid Change
    Apr 2015
    Yeah, and you can use either gender fluid in the tranny .
  16. #16 Re: Second Thoughts About Transmission Fluid Change
    Newnan, GA
    I have had dex 6 in my 4t60e (97 GT) for a couple years now.
    It is the most reliable part of my car.
  17. #17 Re: Second Thoughts About Transmission Fluid Change
    Jul 2010
    Coquitlam,BC,Canada
    I have had the same 1-2 shudder issue since buying the GP 5 years ago. Did the shift kit in year 2 and change the fluid at least once a year, if not twice. I did throw in half a bottle of Lucas last year, but never noticed a difference. I think I'm one of the lucky one's, as my tranny has acted and stayed the same over the years.
    Oh, and my last tranny service (last month) I put in Dex 6. So far no issues.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #18 Re: Second Thoughts About Transmission Fluid Change
    Buffalo
    There is nothing wrong using dex6. Some people decide to switch to it AFTER a new build or rebuild.
    But just doing a pan drop, dex3 would be the CHEAPEST route
  19. #19 Re: Second Thoughts About Transmission Fluid Change
    Jul 2010
    Coquitlam,BC,Canada
    I'm sure it will be fine, but I usually don't put newer types of fluid in my older applications. Newer stuff is more synthetic, which can be an issue on tired parts.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  20. #20 Re: Second Thoughts About Transmission Fluid Change
    Buffalo
    That is another valid point I been searching for a while. I wanted a FULL syn dex6 and only valvoline brands states that on their bottles.
    No other dex6 I seen says that.
  1. Transmission Fluid and Filter change at 98k?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2015, 12:41 PM
  2. Transmission fluid change, Dealership or Typical Oil Change place?
    By bjornbjorn in forum General Grand Prix Discussion
    Last Post: 09-20-2013, 10:38 PM
  3. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  4. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  5. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
