Thread: 2003 broken CV Axle HELP!
Results 1 to 9 of 9
  1. #1 2003 broken CV Axle HELP!
    Mar 2016
    PHoeniz
    Hello everyone. I buy a pontiac grand prix with bad transmission , and when I started to change I found a broken axle cv on the right side inside the transmission.I need help to remove it. any help is appreciated
    thank you!
    i can`t upload pictures to server, here is a couple pictures.
    https://gyazo.com/a9d7486cf9464932d2731ad626c75dc3
    https://gyazo.com/8915e81d83a103ef4de6ef05a110f0dc
  2. #2 Re: 2003 broken CV Axle HELP!
    wow, thats snapped off alright.
    im not 100% sure but you may have to take the diff cover off to get that out.
    or weld a long bolt to it and then use a slide hammer to pop it out.
    i think i see the C clip in the diff there, pull that out and try a magnet, only thing that holds it in is the clip.
  3. #3 Re: 2003 broken CV Axle HELP!
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    DAMN. I'd try hook it or something
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #4 Re: 2003 broken CV Axle HELP!
    Mar 2016
    PHoeniz
    i gonna try to remove the cover and try take out, do you tink this was the problem on the transmission or the transmission is bad?
  5. #5 Re: 2003 broken CV Axle HELP!
    theres a chance the tranny is still good. a busted axle would make think somethings awful wrong for sure. last owner likely beat the tar out of it, only way i see that snapping.
    you need a new axle anyways, so fish that one out, then slap the new one in, could save yourself a ton or r and r time.
  6. #6 Re: 2003 broken CV Axle HELP!
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    If and when you get it out and replace the axle I would jack up the front and put the car in neutral and spin the wheels to see if they turn. Then try putting it in gear to see if the axle/trans even turns. Something may have locked up inside it causing that axle to snap like that.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  7. #7 Re: 2003 broken CV Axle HELP!
    Kemmerer, Wyoming
    I'm pretty sure if you take the differential cover off, the transmission fluid will leak out, just an fyi.
  8. #8 Re: 2003 broken CV Axle HELP!
    Mar 2016
    PHoeniz
    thanks for your help, I could finally get out. The previous owner was removing the transmission and lift from the oil pan i have to change anyway and gave me more room to work, with the help of washers it was easy .I can turn the wheel on the other side and turns free. also I turned to the differential and turns free too, I feel nothing stuck.
    I need to put together everything that the previous owner removed and see how it works the transmission.
    Thank againg!
    a few picture more:
    https://gyazo.com/56f8e655bd8b9a7a637866dba9ef9718
    https://gyazo.com/dee6acfe9ead9b666f687671cbb692c4
    https://gyazo.com/8ce6ad48ff1c8091c41a9d2862ffb785
    https://gyazo.com/bafe5c3fb2f499dd87a961694ed19cd5
    https://gyazo.com/6f33f5fbc28098a07745b76d2164f4b1
  9. #9 Re: 2003 broken CV Axle HELP!
    Mar 2016
    PHoeniz
    in the third picture the transmission was turning normal when the axle broke.if the transmission had been stuck. it would look broken to the right and not the left. or am I wrong?
  1. Broken axle or diff? Or worse?
    By dbcruzr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-11-2014, 10:39 PM
  2. Old Thread
    By SpeedGrid in forum General Tech Discussion
    Last Post: 09-03-2012, 09:23 PM
  3. Possible Bad CV Axle?
    By mlasnoski in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2011, 02:47 PM
  4. Is my axle going out?
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2010, 07:05 AM
  5. 2003 GT vs 2003 mitsubishi eclipse GTS
    By kjohnson in forum Track Sessions and Kills
    Last Post: 04-01-2009, 11:27 AM
