Hey guys I have a question about my daughters 99 GTP.
She had what started as a water pump issue which led to the belt coming off and stranding her. She then told me that she cannot get the trans to shift from neutral to R or P.
The Shifter is in neutral and will pull back to drive but will low pull back to lower gears or move forward to neutral or park. Also for a while now she has been having to stick something down in the little override slot to get it to go into park.
When I had the car towed to my house the tow truck guy left the key in the accessory position and killed the battery because the key would not turn all the way back. Apparently my daughter also uses a small screwdriver to push up on the hole under key to allow it to turn back.
The car shifts fine and the trans seems completely fine. It just is a solid stop when you try to move the shifter from neutral to R or P.
any ideas? Neutral safety switch? Coincidence that it just happened at the same time the belt issue happened?
