Thread: '04 Trans Swap - What parts should I replace on donor trans before installation?
Results 1 to 20 of 22
  1. #1 Re: '04 Trans Swap - What parts should I replace on donor trans before installation?
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    If there's future plans to start a serious build start with a 04 comp g trans I'd say
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  2. #2 Re: '04 Trans Swap - What parts should I replace on donor trans before installation?
    Quote Originally Posted by Travisgt2 View Post
    Why in the hell would u recommend that
    04 Comp G.
  3. #3 Re: '04 Trans Swap - What parts should I replace on donor trans before installation?
    it only works in a real comp g is the point. they are hard enough to find when you really need one too.
  4. #4 Re: '04 Trans Swap - What parts should I replace on donor trans before installation?
    Quote Originally Posted by ScottyDoggs View Post
    This, Goodluck finding one in the JY.
    Just stop Travis unless you know what your talking about.
    04 Comp G.
  5. #5 Re: '04 Trans Swap - What parts should I replace on donor trans before installation?
    Jan 2013
    leavenworth ks
    Why do they only work in another comp g why can't you take the pcm and transfer it all to another of the same year?
  1. has the trans been replace before?
    By mngtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-09-2015, 10:14 PM
  2. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  3. Installation of trans cooler video
    By 2007 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-15-2013, 09:44 PM
  4. installation of tep trans cooler
    By 2007 in forum How To Write-Ups/Tech Tips
    Last Post: 07-30-2013, 09:37 AM
  5. installation of triple edge performance trans cooler
    Last Post: 05-14-2013, 09:59 AM
