Thread: 04 GP replacing trans with used one info
Results 1 to 5 of 5
  1. #1 04 GP replacing trans with used one info
    Donating Users
    Illinois
    Thought I would double check on here, have a 04 GP with a trans going bad , while checking on getting a used one was told that 04 GP are 1 year only transmissions (only a 04 transmission will work) can anyone on here verify that or have an other info on this??
    thanks
  2. #2 Re: 04 GP replacing trans with used one info
    2004 is not a year only, not sure were you read that or got that information.
    Aslong as the transmission from another NA 3.8 GP from 04-08 is should drop in just fine.
    The Comp G and GTP transmissions are different because of electronic controls and gear ratio's.
  3. #3 Re: 04 GP replacing trans with used one info
    Donating Users
    Illinois
    Got it from the salvage yard that I called to find one
  4. #4 Re: 04 GP replacing trans with used one info
    hangover park IL
    the only thing you may have to do is swap in your 3.05 FDR diff in, if the trans is from a bonnie/impala/etc as they may have the 3.29 FDR diff (fdr = final drive ratio)
    ~James~ Psychotic Gearhead
  5. #5 Re: 04 GP replacing trans with used one info
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    Quote Originally Posted by dhdolphns View Post
    thanks
    Got told the exact same thing; maybe it's a glitch in their database, but with the 04s being beta-test cars as it is, maybe there's something in the early production (mine was built 1/14/2004) models that's slightly different, but wouldn't prevent a swap from a newer donor! Still, if there's no difference in the Gen 9 GP's transmissions for L26 cars, that's a relief!
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  1. 02 Impala trans info needed
    By FordMan77 in forum Off Topic Discussion
    Last Post: 09-16-2014, 11:07 AM
  2. Trans Info?
    By speed demon in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-08-2014, 07:10 AM
  3. Trans info/links
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 07-19-2012, 09:33 AM
  4. Looking for Trans Rebuild Info
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2008, 12:03 AM
  5. 4T65E Trans Info Link
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-13-2007, 04:01 PM
