sometimes when it shifts it sits for a few second and then kicks in. this mainly happens from 1st to 2nd gear.
the only code I'm getting is P0650 which I have found means the cel is supposed to be on but someone turned it off. I was wondering if other codes would . with that if they were there or does that hide the other codes?
I'm about to check the fluid when I can. I found the steps on line because I don't have an owners manual.
