Thread: No 3,4th gear. torque converter question...
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: No 3,4th gear. torque converter question...
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    Ill have to read that a few times, I am going to see if my original fittings have the check ball or not
  2. #22 Re: No 3,4th gear. torque converter question...
    Aug 2012
    Chicago
    OK after reading especially post # 6 from the link you provided. I have no idea what year the replacement tranny came from. maybe a 98-99.
    So I gather that I cannot put my quick connect fittings from the 2000 on this "1999" transmission. So they are not 100% interchangeable. I got that part.
    So i will need to....
  3. #23 Re: No 3,4th gear. torque converter question...
    Mar 2014
    Tucson
    They are 100% interchangeable. Had the exact same scenario on my brothers car. Put a trans from a '99 Regal into his '02 Regal. Pulled the push lock fittings from the smoked trans and put them in the donor trans. Didn't know about the check ball in the cooler feed fitting at the time so it's still in there.
    Just swap the fittings. You'll be fine.
  4. #24 Re: No 3,4th gear. torque converter question...
    Aug 2012
    Chicago
    Thanks I sent you a pm.
  5. #25 Re: No 3,4th gear. torque converter question...
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Well the one on the bottom is the forward apply band I pulled out of your trans.. Lmao
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  6. #26 Re: No 3,4th gear. torque converter question...
    Aug 2012
    Chicago
    Well that would explain no 3/4 lol . I hope they have some sort of hardened aftermarket band .
  7. #27 Re: No 3,4th gear. torque converter question...
    Mar 2014
    Tucson
    Quote Originally Posted by m17davis View Post
    Is there any indication of why the lug broke off? Heat checks, stress cracks, fatigue? Anything? It appears to have the high energy lining, which would indicate a later build.
  8. #28 Re: No 3,4th gear. torque converter question...
    Orland Park, IL
    No. Everything looked great
  1. Torque converter question
    By m17davis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-14-2015, 02:26 PM
  2. What torque converter for 99 gtp
    By Derbeck in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-12-2014, 03:45 PM
  3. Torque Converter
    By gtp99jlp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-24-2013, 06:12 AM
  4. Question: Tranny Torque Converter lock/unlock issue
    By Lawngoose in forum General Tech Discussion
    Last Post: 05-31-2009, 09:54 PM
  5. Torque converter ?
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 04:47 PM
