Thread: 05 guage cluster issue
Results 1 to 4 of 4
  1. #1 05 guage cluster issue
    Jul 2014
    ohio
    Messing with my 05 gp i killed the battery. I jumped it and all my analog guages stopped working except the speedometer. Is there a common fuze or relay that pops when jumping these cars? Thanks
  2. #2 Re: 05 guage cluster issue
    St. Louis
    Not usually, but now would be a good time to break out the owners manual and see what fuse controls the instrument panel and check to see if it's blown.
  3. #3 Re: 05 guage cluster issue
    Jul 2014
    ohio
    Broke out the test light and couldnt find any blown. A new battery was on my list anyway so just replaced it and go figure guages are up and running. I've never seen a car do that with a nearly dead battery.
  4. #4 Re: 05 guage cluster issue
    St. Louis
    These cars are sensitive to electrical issues. Even a loose or dirty battery cable can cause strange things. I could see a weak battery causing similar issues. Not as cheap a fix as a fuse, but it won't leave you stranded due to a bad battery now either.
  1. Switching guage cluster lights to blue?
    By Xanthous in forum Visual/Body Modifications
    Last Post: 08-06-2011, 07:54 AM
  2. cluster guage lights inop
    By triskit527 in forum General Tech Discussion
    Last Post: 03-29-2010, 09:07 PM
