Thread: 08 gp holes under back seat
Results 1 to 7 of 7
  1. #1 08 gp holes under back seat
    Apr 2013
    Wi
    Im still new here i think i have this in the right place, but yesterday i had my back seat out and i moved the carpet towards the front of the seat and i noticed i could see the ground. This was on the passenger side almost center of the passenger seat toward the front of where the back seat sits, then i turned around and noticed another hole on the driver side same spot, theyre not rusted through. My question is, is that hole supposed to be open or is there supposed to be a plug in it. It is noisier when riding in the back seat compared to in the front.
  2. #2 Re: 08 gp holes under back seat
    I would assume there were suppose to be rubber plugs in those spots and that they came out somehow.
  3. #3 Re: 08 gp holes under back seat
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    I noticed that a few months ago and mine isn't rusted or anything either. I was thinking of filling it with foam or plugging it to see if it makes a sound difference
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  4. #4 Re: 08 gp holes under back seat
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    im pretty sure the holes you are referring to are where the seat plugs into...
  5. #5 Re: 08 gp holes under back seat
    Spring Lake, Mi
    Yeah, because those holes would go straight through the car...
    there is like a cavity under the metal that supports the rear seats and it could also be for drainage
  6. #6 Re: 08 gp holes under back seat
    Apr 2013
    Wi
    The seat does not go into these holes, if i plug them water wont be able to get in there so i wouldnt need drainage holes? Or is there somewhere else water gets in from
  7. #7 Re: 08 gp holes under back seat
    Spring Lake, Mi
    Well if you spill a few gallons of water in your back seat maybe. But what good is plugging them really doing you?
  1. INFORMATION Do You Know What's Living Under YOUR Back Seat??
    By 2dee11 in forum Detailing Tips and Tricks
    Last Post: 08-26-2013, 10:12 AM
  2. Back seat in 1998 gtp
    By Xereck in forum Audio, Security & Visual Electronics
    Last Post: 01-13-2012, 04:17 PM
  3. back seat opening
    By littleharv93 in forum General Tech Discussion
    Last Post: 05-31-2011, 10:04 PM
  4. how do you remove the back seat?
    By 2000GTP in forum General Tech Discussion
    Last Post: 10-26-2008, 08:11 PM
  5. Rust behind and under back seat
    By 03GPScottyd in forum Visual/Body Modifications
    Last Post: 01-04-2008, 03:36 PM
