Thread: lost torque with cai
Results 1 to 20 of 34
  1. #1 lost torque with cai
    Apr 2013
    washington
    I have installed a 4" 45* bend off of the tb then to Maf then to 4" spectre filter housed in a heat shield. I lost so much low end tq that the wheels with only churp a few seconds rather then the whole national anthem. my question is does it have to do with the maf location or the 4" bend. or is the computer adding top end HP do to the increased air flow. is a loss of tq normal on a cai?
  2. #2 Re: lost torque with cai
    Dec 2010
    DMV
    Any codes? You shouldn't feel a loss of power with a cai.
  3. #3 Re: lost torque with cai
    if anything my car feels a bit ( i do mean a bit, nothing to write home about) faster off the line with the hai, i can roast the tires at will from a dead stop. and i got 225,000 miles.
    seen what you have for a set up before with no problems.
  4. #4 Re: lost torque with cai
    SWPA
    Only way you lost power is if you screwed something up.
  5. #5 Re: lost torque with cai
    Apr 2012
    Goderich, Ontario
    How do you screw it up? Haha. What year is it? 97-03 doesn't effect the maf. Upload a pic.
    -Paul Walker
  6. #6 Re: lost torque with cai
    Apr 2013
    washington
    here is a picture its an 04 gtp 90,000 miles I thought maybe with the maf at the filter low air speeds were disturbing the maf reading because as soon as air speeds pick up so does engine power. no codes. http://img109.imageshack.us/img109/6...2425111820.jpg
  7. #7 Re: lost torque with cai
    Apr 2012
    Goderich, Ontario
    Try putting the maf closer to the tb and see if it helps (mabe infront of the 45* bend). I dont think that will but its worth trying.
    -Paul Walker
  8. #8 Re: lost torque with cai
    SE Level Member Reverant GTP's Avatar
    Iowa
    Did the torque loss happen immediately after install? Are you getting full boost?
  9. #9 Re: lost torque with cai
    SWPA
    Where is your PCV? If you didn't hook that back up you have a massive vacuum leak. If you just plugged it you could be causing other issues.
  10. #10 Re: lost torque with cai
    Apr 2013
    washington
    torque lost did happen immediately after install. don't know about boost yet as my obd2 dongle won't be here till Monday. the torque app will give me more insight. I have heard a few people say to put the maf with a pipe after to smooth airflow but did not think it would make a difference since the maf has that diffuser screen to straighten the air out. I think I will try to put the maf after the tb maybe later today or tommorow as I have to grab a 3" coupler and new pieces to fit that 9" filter in there. thinking about a fwi also but my filter stays cold already so not sure if it would make a dfference.
  11. #11 Re: lost torque with cai
    Apr 2013
    washington
    hard to see but there is a Hole in the coupler PVC is hooked up I've checked it a few times because that was my suspicion.
  12. #12 Re: lost torque with cai
    Ohio
    Please tell me how you are going to go about putting the maf after the tb?
  13. #13 Re: lost torque with cai
    Apr 2013
    washington
    3" coupler from tb to Maf housing is how I would do it.
  14. #14 Re: lost torque with cai
    Apr 2012
    Goderich, Ontario
    You mean before the tb? Filter-tube-maf- tb
    -Paul Walker
  15. #15 Re: lost torque with cai
    Apr 2013
    washington
    I see why the confusion. I was speaking in the order of tb, maf ,tube, filter. hence the maf after the tb. so has no one expierence a loss in low end from a cai? I know that alot of the forum members have pre 04+ gp with the maf mounted on the tb so there isn't a hole Lot of information on intake behavior of the 04 gp. I will post information on maf readings and such Monday or Tuesday with different setups to see if there are air disturbances with different locations of the maf.
  16. #16 Re: lost torque with cai
    Apr 2012
    Goderich, Ontario
    No matter what your set up is, the car should drive the same as it did before only louder.
    -Paul Walker
  17. #17 Re: lost torque with cai
    Apr 2013
    washington
    wouldn't more air to the blower equal more power?
  18. #18 Re: lost torque with cai
    Apr 2013
    washington
    well it doesn't it feels like the power band shifted higher in the rpms. faster on highway slower from a stop.
  19. #19 Re: lost torque with cai
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    Check your maf and see if the plug is still facing at the same angle as stock and facing the right direction. I installed mine at a weird angle and had issues but I have an lt1 maf so it might not matter for you but it did for me. Just a suggestion
  20. #20 Re: lost torque with cai
    Chilliwack BC
    as said above i gained more throttle response but barely noticeable...definately shouldn't be worse. my not s/c grand prix will spin tires all day long if i WOT
  1. What is lost with new hu?04+
    By rriggs92 in forum Audio, Security & Visual Electronics
    Last Post: 05-12-2013, 12:43 AM
  2. Replies: 7
    Last Post: 04-19-2012, 12:44 AM
  3. im lost!
    By adamLG in forum General Tech Discussion
    Last Post: 06-21-2011, 05:39 AM
  4. HELP lost 1st and 4th
    By davidl25 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-26-2009, 05:42 AM
  5. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
