Thread: spark plugs & gapping
Results 1 to 8 of 8
  1. #1 spark plugs & gapping
    SE Level Member drewzilla03's Avatar
    Jul 2011
    minnesota
    what are the appropriate/correct/safe plugs & gapping for the following:
    07 GP GT supercharged.
    180 t-stat
    headers
    pully drop (3.6)
    overkill pcm
    apprciate any input from someone with a "simillar" setup.
    thanks
  2. #2 Re: spark plugs & gapping
    I run 605's autolite copper cores on my headers/3.6/self tuned 2000 GTP.
    I run a .055 gap, works fine. Just note that with copper core plugs they only last around 15k miles.
  3. #3 Re: spark plugs & gapping
    Jul 2011
    minnesota
    can i assume the .055 would be the same for any plug ???
    i would want plugs that last longer
  4. #4 Re: spark plugs & gapping
    The car calls for a .060 gap stock, I'd rather go .055 because its a personal choice.
    If you don't plan on modding further, I'd say if you went with the stock ac delco plugs it should be alrgiht.
    The thing is, when you add more power to the car, there is a point where the factory spark plugs are too hot, its the reason why many of us will run a cooler plug.
  5. #5 Re: spark plugs & gapping
    Jul 2011
    minnesota
    it looks like al605's are a good fit...i'll try .055
  6. #6 Re: spark plugs & gapping
    Jan 2009
    Tallahassee, FL
    Really the only reason to run a smaller gap is if your spark is blowing out. I actually had some knock after I gapped some plugs down a little, gapped them back to stock and the KR went away.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  7. #7 Re: spark plugs & gapping
    Jul 2011
    minnesota
    good to know...i'm just not sure if an open cone air intake, headers, and a 3.6 pully drop are "enough" to justify a colder plug or differant/smaller gapping...
  8. #8 Re: spark plugs & gapping
    Jan 2009
    Tallahassee, FL
    Stay at the stock gap, you could run 605s instead of 606s to be a little safe, but I think you'll be fine on 606s
    77 Morris Garage B
  1. Spark plug gapping
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2012, 05:12 PM
  2. 06 GP 3.8 looking for spark plugs
    By chas300x6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-09-2012, 02:13 PM
  3. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  4. Side-gapping plugs should I upgrade wires?
    By whineaddict in forum General Tech Discussion
    Last Post: 04-11-2009, 10:33 AM
  5. spark plug gapping?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 10:15 AM
