Thread: Spark plug gapping
Results 1 to 20 of 20
  1. #1 Spark plug gapping
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Ok guys, Got the xp cam in, Heads just came back from the machine shop so it's time to put her back together.
    I got Autolite 103's but I don't know what to gap them?!
    Any help please.
    Thanks in advance.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: Spark plug gapping
    Pennsylvania
    What supercharger?
    What pulley size?
  3. #3 Re: Spark plug gapping
    Boost level is a good place to start.
  4. #4 Re: Spark plug gapping
    Oct 2012
    New Jersey
    Stock Ported S/C, Ported Lim & Heads
    3.4 Pully, Might drop to 3.25
    Is there a formula for figuring this out? or pure experience?
  5. #5 Re: Spark plug gapping
    Pennsylvania
    Your 103's are too cold. Use Autolite 104's gapped to 0.060".
  6. #6 Re: Spark plug gapping
    Oct 2012
    New Jersey
    Quote Originally Posted by SlowNA06 View Post
    Thanks for your input. What makes you say they are too cold? I was told by a few members to use 103's... I'm just curious as to how you feel 104's would run hotter?
    Thanks
  7. #7 Re: Spark plug gapping
    Out West
    .050 -- 104's will be great on a 3.25
    save the 103's for 3.1 or lower.
    Whine with your Cheese?
  8. #8 Re: Spark plug gapping
    You want to run the hottest spark you can.
  9. #9 Re: Spark plug gapping
    Oct 2012
    New Jersey
    Right, I just don't know how to tell which plug will run hotter and why...
  10. #10 Re: Spark plug gapping
    Out West
    the higher the number, the hotter it is.
  11. #11 Re: Spark plug gapping
    Pennsylvania
    I've put Use Autolite 104's gapped to 0.060" on a 3.4" GenV setup running more boost than yours (more restricted exhaust) and had no knock or "spark blowout" issues. Anyone telling you to gap smaller probably hasn't actually experienced spark blowout and is just parroting something they heard. As for the plugs - ALWAYS start with the hottest plug you can, scan for knock, then go a single step colder as needed. The most common spark plug used in 3.4" pulley setups is only two heat ranges colder than stock; the AL104.
  12. #12 Re: Spark plug gapping
    I just use a low gap because Nick's are lazy.
  13. #13 Re: Spark plug gapping
    Pennsylvania
    Was wandering around the internets...
    Spark Plug Choices - RegalGS
  14. #14 Re: Spark plug gapping
    I remember that mess from ZZP's tech article from back in the day.
    Pretty sure at least...
  15. #15 Re: Spark plug gapping
    Quote Originally Posted by Tuner-Extraordinaire View Post
    Unless you're buying NGK.
    Lol at TR55 being one step colder, and even better, TR6 being two steps.
  16. #16 Re: Spark plug gapping
    Here...from my thread:
    Spark Plugs - Change out those stock spark plugs with new ones to restore any lost power. Brands that most tend to go with are either Copper Core Autolites or NGK's. They range as follows in order from hottest to coldest plugs...remember...you want the hottest spark you can get away with...so running a super cold plug on a larger pulley to combat knock isn't the best plan...OEM replacement ACDelco's, AL606's, and AL605's are basically for stock cars or very small bolt-ons still running the stock S/C Pulley or modded N/A guys...you want to keep a hot spark. NGKTR55/AL104's for your 3.4" Setup, TR6's are a tad cooler...best used around the 3.25" pulley area, and AL103's...are for the extreme supercharged application...3.0" pulley or lower. Here is a picture to reference the firing order and the correct coil number if yours aren't numbered or you just need a quick reference picture: http://i33.photobucket.com/albums/d6.../plugwires.jpg
    AC Delco Factory Replacements: Stock
    Autolite 606: Stock
    Autolite 605: 1 Heat Range Cooler
    NGK TR55: 1 Heat Range Cooler
    Autolite 104: 2 Heat Ranges Cooler
    NGK TR6: 2 Heat Ranges Cooler
    Autolite 103: 3 Heat Ranges Cooler
  17. #17 Re: Spark plug gapping
    tell me then why its listed as stock replacement by NGK?
  18. #18 Re: Spark plug gapping
    frumwhere
  19. #19 Re: Spark plug gapping
    NGK Spark Plugs USA
    2000 PONTIAC GRAND PRIX GTP 3.8 V6 1 FI Supercharged
    Spark Plug
    Part No.
    Stock No.
    Plug Gap
    V-Power TR55
    3951
    .060
    G-Power TR55GP
    3403
    .060
    Laser Platinum PTR4B-15 * #
    5146
    .060
    OE Laser Iridium ITR4A15 ^
    5599
    .060
    Iridium IX TR55IX
    7164
    .060
  20. #20 Re: Spark plug gapping
    Because it's changed over the years?
    You want to buy plugs for a V6 Ranger anyways.
  1. Spark Plug Gap
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 10-14-2012, 09:57 AM
  2. which spark plug?
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2012, 07:39 PM
  3. Spark plug
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-01-2011, 02:48 AM
  4. Plug Gapping
    By sinceregtp in forum General Tech Discussion
    Last Post: 10-11-2009, 12:04 PM
  5. spark plug gapping?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 10:15 AM
