Thread: Help with 2007 Dash Rattle
Results 1 to 20 of 27
  1. #1 Help with 2007 Dash Rattle
    Donating Users
    Oct 2008
    MN
    Hello,
    First post on this site... I have a nasty rattle that seems to be caused by the clear plastic window over the instrument cluster that is driving me nuts! Car only has 1200 miles. I stopped by the dealer, but of course it would not rattle then...
    Anyone address this problem on their car? Thought I would check before I start tearing things apart...
    Thanks!
  2. #2 Re: Help with 2007 Dash Rattle
    Donating Users Dboy23's Avatar
    Aug 2008
    Michigan
    It's hard to tell you if I don't hear it myself, if the dealer doesn't have a fix neither do I.
    *sig is too tall*
  3. #3 Re: Help with 2007 Dash Rattle
    Donating Users
    Oct 2008
    MN
    found the rattle... being caused by the lower dash panel near your knees. A little weather stripping at the contact points took care of it...
    2007 GT. Upgraded front & rear sway bars. Firestone Snow & Ice Tires five months of the year!
  4. #4 Re: Help with 2007 Dash Rattle
    Jul 2008
    Tampa, FL
    man, i've had the same problem since i got mine in july! must be an 07 thing! i will look into that! thanks!
  5. #5 Re: Help with 2007 Dash Rattle
    Donating Users
    Oct 2008
    MN
    the extra weather stripping helped for a while, but it is back! The panel is flimsy lite-weight plastic that is secured by push-pin style connectors. I may try a couple of screws to hold it solid...
  6. #6 Re: Help with 2007 Dash Rattle
    Jul 2008
    Poteau Oklahoma
    my wifes has one right above the instrument cluster. its an 06.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  7. #7 Re: Help with 2007 Dash Rattle
    Louisiana
    we have an '06 model and the dash rattles like you wouldn't believe. I've taken it off twice and to no avail it still rattles.
  8. #8 Re: Help with 2007 Dash Rattle
    Donating Users
    Oct 2008
    MN
    I used a single flat-head sheetmetal screw in the center of the "knee panel", running the screw straight up (via a pilot hole I drilled) into the metal brace/bracket just above the need panel (up towards the steering column). There is about a 1/4 or 3/8" gap between the plastic panel and the metal brace. I only ran the screw tight enough to put pressure on the plastic panel, and not so tight that it would warp the panel. Since the screw is down past your knees, it is out of sight (plus the black screw matches my black panel), and my rattle has been non-existent for several months!!!
    Now if I can figure out the annoying rattle & squeak in my headliner / sunroof area...
  9. #9 Re: Help with 2007 Dash Rattle
    Jul 2008
    Tampa, FL
    Quote Originally Posted by leeklm View Post
    pics? i'm still battling mine...grr, although i think mine is caused by the gauge cover on the top piece...
  10. #10 Re: Help with 2007 Dash Rattle
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    replace the plastic push connectors. use weatherstripping or backer rod to fill in the gap and it should go away and never come back.
    I used these tricks on several iron chevies and have used it on my 07 gp as well.
  11. #11 Re: Help with 2007 Dash Rattle
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    Well u can take it to the dealership for warenty if your still under the 3yr 36k
  12. #12 Re: Help with 2007 Dash Rattle
    Donating Users
    Oct 2008
    MN
    I did take it to the dealer once. I bought the car new last october, it sat on the lot for almost 2 years! (so I got a great deal ) Of course it did not rattle when I brought it in, so they were of no help. I decided it was easier to deal with it myself, than some hack who really does not care about it. My buddy is a 20+ year dealer mechanic, and says that they despise trying to diagnose "rattles".
    Thanks for the tips.
  13. #13 Re: Help with 2007 Dash Rattle
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    my 06 does it..dosen't really bother me cause music is always up
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  14. #14 Re: Help with 2007 Dash Rattle
    Donating Users
    Oct 2008
    MN
    True, the Monsoon does take care of many squeaks & rattles! Although I am pleased with the car (especially considering what I paid), Pontiac would have really had a great car here if they would have spent just a little more time on the interior. Oh well, it is the least of their worries now...
  15. #15 Re: Help with 2007 Dash Rattle
    Aug 2008
    Fayetteville, NC
    ^ yep considering they stopping making GP's in 2008
  16. #16 Re: Help with 2007 Dash Rattle
    Jul 2008
    Tampa, FL
    I'm right at 38k miles, you think a dealer would honor my warranty since i've had the rattle since i bought the car?
  17. #17 Re: Help with 2007 Dash Rattle
    Dec 2008
    colorado
    Quote Originally Posted by vailskier3 View Post
    Depends if u had taken it into them before they probally would. Or if they really like you. Try it never hurts to ask
  18. #18 Re: Help with 2007 Dash Rattle
    Donating Users
    Oct 2008
    MN
    I originally thought mine was over the instrument cluster as well. Easy way to tell... When it is rattling, reach down and apply some pressure to the panel by your knees. If it stops rattling, you found it. Guy at the office has a 2006 with same problem.
  19. #19 Re: Help with 2007 Dash Rattle
    Jul 2008
    Tampa, FL
    it seems as though when it rattles and i touch the top part, it stops. i'm pretty sure its the top piece. when i tap on the bottom part, the top rattles as well, so i guess i will need to try to fix that somehow...
  20. #20 Re: Help with 2007 Dash Rattle
    Donating Users
    Oct 2008
    MN
    while diagnosing my rattles, I removed the dash piece on top of the instrument panel (pulls right off), and applied weather stripping material (I used pickup topper tape that was laying around) to the edges that looked to make contact with other plastic components, like the clear plastic instrument window, etc. Not sure if it did much since my primary rattle was the knee panel, but did not hurt!
  1. Supercharger noise, rattle HELP!
    By Mvfootball1 in forum General Tech Discussion
    Last Post: 08-26-2010, 04:49 PM
  2. Rattle Trap....
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 07:11 PM
  3. 3.5 pulley on 2007 GP/GT
    By 07 GPGT in forum General Tech Discussion
    Last Post: 08-22-2008, 12:21 AM
  4. Valves rattle
    By johndaysGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 05:46 PM
  5. Mods for 2007 3.8
    By BrianHoward in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-27-2008, 07:08 PM
