Thread: Running a power wire
Results 1 to 10 of 10
  1. #1 Running a power wire
    Aug 2012
    New York
    Okay so i feel like a complete noob asking this since i have wired up 2 or 3 other cars with amps and subs and speakers but, i cant seem to find a place in the firewall that theres an existing place to put a wire through. I am wondering where you guys have either drilled a new hole for a power wire or if theres a place that im just missing that i can run it through? All help is very appreciated.
  2. #2 Re: Running a power wire
    Omaha, NE
    It should fit nicely through the shifter boot in the firewall. You may need to make a slit in the boot to help it fit through.
  3. #3 Re: Running a power wire
    Houston
    What year car? On the 97-03's there is a grommet on the passenger side firewall, down by where the power steering pump is.
  4. #4 Re: Running a power wire
    Aug 2012
    New York
    its a 05 grand prix base model. where would i find the shifter boot in the firewall?
  5. #5 Re: Running a power wire
    Omaha, NE
    Passenger side I wanna say 6-8" from the strut tower and about half way up the firewall. Its a rubber grommet.
  6. #6 Re: Running a power wire
    Aug 2012
    New York
    ok thanks im going to go try that now, thanks for the help!
  7. #7 Re: Running a power wire
    Aug 2012
    New York
    okay so i got the power wire run and everything and all the other wires needed and i had a subwoofer already installed in my car(paid to get it done) and i just wired up speakers to a new amp. for some reason that i cant figure out it will power and play music from my speakers and after it reaches a certain music level it turns off for some reason? ive checked all the connections and cant seem to figure it out. im not sure if anyone here would really know what to do or if i should go to an audio forum lol
  8. #8 Re: Running a power wire
    SE Level Member crysalis's Avatar
    Mentor, OH
    Your amp isn't getting enough power. Bigger alternator, better battery and possibly consider a capacitor.
    Are you running the proper gauge wire for your amp? How many watts at what resistance?
    2006 GP GT S/C | CAI | Overkill PCM | PLOG | 3" Catted DP | ZZP Strut Brace -- SOLD the car in treason for a Hemi Charger >:]
  9. #9 Re: Running a power wire
    Houston
    Have someone slowly turn up the volume and use a DMM on your battery and look for a significant voltage drop. Also, what is the impedance on the sub?
    Quincy, Mass
    What size power wire did you run? Where did you ground it too and did you scape the paint away to make sure you got a good ground?
    No more GP 04 Impala SS Indy:
  1. running amp power wire question
    By bps02gtp in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2012, 12:21 AM
  2. Running amp power wire
    By c40verload in forum Audio, Security & Visual Electronics
    Last Post: 10-19-2011, 01:26 PM
  3. new power wire
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 12-23-2009, 03:35 AM
  4. Where to run power wire?
    By 97gp97 in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 02:21 PM
  5. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
