Thread: how to remove "Service Tire Monitor System"
Results 1 to 20 of 21
Threaded View
  1. #18 Re: how to remove "Service Tire Monitor System"
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Quote Originally Posted by michaelbm View Post
    If you choose to keep the 07 dic in addition to the four wheel sensors you will need a 07 keyless entry reciever as well.
    This part changed in 07 because it has to be capable to receieve signals from the pressure sensors, The connectors are different just enough that they wont plug in so you will have to splice a connector or make an adapter harness and make a slight wiring modification so the keyless entry reciever has a direct link to the serial bus of the car.
    The keyless entry reciever sends the tire pressure data over the serial bus where the dic picks it up and displays it.
    The keyless entry reciever will have to me reprogramed for your new remotes, as well as learning the tire sensors.
    Clearly he's already got it installed, and I doubt he needed to do any of that. Also, the DIC receives its data through a Class II data line so everything is serialized, meaning there really aren't that many individual signals going into it. If you need more information to go to the DIC (e.g. TPMS sensors) you just serialize it into the data stream and then update the software on the DIC.
    Edit: Somehow I misread a lot of your post lol so most of my garbage can be disregarded. My bad :P
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  1. 97 Grand Prix GT "check tire pressure" light on
    By fju2 in forum General Tech Discussion
    Last Post: 08-04-2011, 07:37 PM
  2. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  3. Service "vehicle" soon, trac off and ABS light all on
    By 98RegalGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2011, 10:45 PM
  4. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
