Thread: how to remove "Service Tire Monitor System"
Results 1 to 20 of 21
  1. #1 Re: how to remove "Service Tire Monitor System"
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Turn the car on, leave it in park and go through the user programming mode in the DIC. I know I've seen the tire inflation monitoring reset in there right next to the oil life monitoring system reset. Then again I do have a 2004 so it might be different, but I would think for the most part it should be the same.
    Also you should've kept your stock DIC because it keeps track of your mileage, so I believe now you've officially violated the law lol (not to mention you wouldn't have the TPMS warnings showing up).
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  2. #2 Re: how to remove "Service Tire Monitor System"
    Oct 2011
    Toledo, OH
    On the 04-05 we only get an overall status like Durk says, ours don't know the actual PSI, only knows changes (and only alerts at a 12PSI change from reset). On the 07-08 it shows all 4 tires at actual PSI in pretty much real-time.
    ALSO the DIC shows the mileage, but the PCM will still have the correct mileage stored. He's only breaking the law if he tries to sell or title the car with the wrong mileage listed.
    7"
  3. #3 Re: how to remove "Service Tire Monitor System"
    Minnesota
    Quote Originally Posted by industrialfish View Post
    I thought it might be the PCM that stores the mileage but I wasn't sure, because everybody's always said it was stored in the DIC (which personally didn't make sense to me).
    2015 Evo MR
  1. 97 Grand Prix GT "check tire pressure" light on
    By fju2 in forum General Tech Discussion
    Last Post: 08-04-2011, 07:37 PM
  2. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  3. Service "vehicle" soon, trac off and ABS light all on
    By 98RegalGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2011, 10:45 PM
  4. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
