Yes. These cars are known to eat window regulators. Once you have the old regulator/motor assembly out of the door you can test the motor. If it works then just install a new regulator. Also lube the felt guides in the window tracks as they like to dry out and cause the glass to stick, thus breaking your regulators. You can break a new one just as fast if the glass does not slide smoothly.
Search on "window regulator" and see what comes up.
