Thread: rear window wont roll up or down? help
Results 1 to 3 of 3
  1. #1 rear window wont roll up or down? help
    Aug 2011
    IL
    I have an 04 grandprix gt and the rear drivers side window doesnt work, been this way since i bought it. You can hear it trying to roll down, sounds like its going to but nothing. Is there an issue with these cars and a howto on fixing this issue? I have searched before posting and couldnt find what i was looking for. Thanks in advance!
  2. #2 Re: rear window wont roll up or down? help
    St. Louis
    Yes. These cars are known to eat window regulators. Once you have the old regulator/motor assembly out of the door you can test the motor. If it works then just install a new regulator. Also lube the felt guides in the window tracks as they like to dry out and cause the glass to stick, thus breaking your regulators. You can break a new one just as fast if the glass does not slide smoothly.
    Search on "window regulator" and see what comes up.
  3. #3 Re: rear window wont roll up or down? help
    Aug 2011
    IL
    Quote Originally Posted by FordMan77 View Post
    Thanks!
  1. Windows roll down fine but roll up SLLLOOOOWWLLYYY
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2013, 07:21 PM
  2. Windows Wont Roll Up or Down
    By MustangMatt96GT in forum General Tech Discussion
    Last Post: 07-11-2011, 06:16 PM
  3. Passenger window will not roll all the way up
    By kevinpope in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2010, 05:39 PM
  4. Bigger rear anti-roll bar?
    By dav305z in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2010, 10:51 PM
  5. Window won't roll up
    By Greenlawnracing in forum General Tech Discussion
    Last Post: 02-22-2008, 11:54 PM
