Thread: Heat extractors
Results 1 to 6 of 6
  1. #1 Heat extractors
    Iowa
    The heat extractors on my GXP dont do a very good job, is there anyway to make thempull more heat out?
  2. #2 Re: Heat extractors
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    make them bigger?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  3. #3 Re: Heat extractors
    Is the path direct?
    Have you studied the areas of heat and the areas of pressure then placed the extractors there?
    the main issue is your block and heads are aluminum, robs heat from the combustion chamber.
  4. #4 Re: Heat extractors
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    Quote Originally Posted by IAGXP View Post
    I don't have a GXP, but are you talking about the "vents" in the quarter panels by the doors?
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  5. #5 Re: Heat extractors
    Wichita
    The GXP heat extractors are blocked. But they can be made functional if you remove the material blacking them.
  6. #6 Re: Heat extractors
    Iowa
    Quote Originally Posted by hklvette View Post
    Yes I am talking about the factory ones
    Thank you I will tear into it more next oil change, I need to spend a day on it anyway. Alignment, balance tires, oil change, trans flush, power wash undercarage.......and the list continues
  1. standard hood mod' for heat extractors?
    By darwal61 in forum Visual/Body Modifications
    Last Post: 12-13-2010, 05:09 PM
  2. 40th anniversary Heat Extractors
    By DEC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2010, 10:41 AM
  3. heat extractors
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 07-18-2009, 02:35 PM
  4. Heat Extractors
    By bula81069 in forum Visual/Body Modifications
    Last Post: 04-04-2008, 08:08 AM
