Several times in the past month my car has cut out( fuel pump stops running) while driving, or won't start because the fuel pump won't run. I jumpered the pump, and it runs fine, enough to get me home. Then it'll work fine for days. Today it's done it and won't come back. Fuel pump runs fine. There is power to the fuse. I haven't tried manually jumpering the relay. I can't seem to get signal from the ign circut that should be there to close the relay. I've never had to do a security re-learn on this car, and it doesn't seem to have a resister in the line.... Any ideas?
