Thread: 06 gp frame flex??
Results 1 to 14 of 14
  1. #1 Re: 06 gp frame flex??
    Barksdale AFB, LA
    Quote Originally Posted by Planeboy18 View Post
    That makes sense with the whole injection thing, but still it's a rip off IMO. That's just JB welding your most important part of the car on.
    It's not JB welding it on. There are parts where two sections are touching but it isn't welded there (but welded elsewhere). These two sections rubbing ever so slightly when the whole subframe flexes (as it must do or it will break, remember this is aluminum) is what causes the noises. Filling the area in between isn't about adding rigidity or strength, it's about adding a cushion material so the metal isn't rubbing anymore.
    My only quarrel with the aluminum cradle that the one on my Impala developed a huge crack in the front passenger side.
    To the OP, if the car is still under warranty maybe I can find the TSB # and you can give it to the dealer to get them to perform the procedure. If you're out of warranty I can still give it to you but the cost is on you.
    2009 Subaru Impreza WRX STI
  2. #2 Re: 06 gp frame flex??
    SE Level Member Planeboy18's Avatar
    Cleveland Ohio
    Quote Originally Posted by Sabrewings View Post
    I know man. I'm just giving you a hard time. I just think it's strange that something like this would happen on a car that's only 3 years old. That is something that should be under warranty though, if it still is under warranty of course. Hope everything works out though.
    04 GP GT (1st car now my G-Ma's):
    97 GP GT (GF's): "Project Pink Power"
    00 VW GTI VR6 (15*V6): Slow and Low, That is the Tempo
    91 VW GTI 8v: Big Plans
  1. noisy flex
    Last Post: 04-11-2009, 01:22 AM
  2. what frame
    By TheGreatSamG in forum General Tech Discussion
    Last Post: 03-10-2009, 12:09 PM
  3. SLP header flex section ticking
    By copterdoctor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2008, 10:29 AM
  4. sub frame
    By YoungGTP in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2008, 02:48 PM
  5. Cool Flex upper rad
    By TNTSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2008, 12:01 PM
