Thread: Cool Flex upper rad
Results 1 to 3 of 3
  1. #1 Cool Flex upper rad
    Hey guys!
    I am really wanting to put in a Cool flex (stainless steel) upper rad hose.
    What I need to know is, What line should I go with? I will need to do just the upper. If this is successful, I will do the lower as well to the water pump.
    Wiz, Wideband O2, 78mm T/B, P&P SC, SSIC, P&P LIM, 3", 1.8CCRR's, CC push rods, Custom covers, SLP headers, Meziere Water pump 3" Magnaflow, Race Tranny, 20" Concept One Wheels, Coilovers, BMR F&R suspension, Custom Body and Paint, Custom interior and sound.
  2. #2 Re: Cool Flex upper rad
    SE Level Member Arkanzan Wheeler's Avatar
    Apr 2008
    Get the longest one you can, that way when you cut off the extra you can use it for the lower hose also, you only need to pretty clamp covers up top anyways. I use this on my truck and it helped with cooling a lot.
    2000 Daytona 500 Edition
  3. #3 Re: Cool Flex upper rad
    I got the RPC universal kit, and I used the 1 1/2" insert.
    I got the 24" kit, but it is not long enough for both, so I just compressed
    it to fit rather than cutting it. That sucker better not leak!
  1. Upper/Lower Air Deflectors (Help cool your car)[*]
    By drunknmunky in forum How To Write-Ups/Tech Tips
    Last Post: 02-20-2012, 11:46 AM
  2. Upper Intake Manifold Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 01-06-2012, 10:34 AM
  3. This is really cool
    By s1795so2 in forum General Tech Discussion
    Last Post: 01-24-2008, 02:32 PM
  4. Upper Gasket
    By TyroElite in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2007, 03:54 PM
