Thread: **HELP** 04 GTP SC shifts but wont drive
Results 1 to 20 of 113
  1. #1 Re: **HELP** 04 GTP SC shifts but wont drive
    Jan 2018
    US
    Looks like these are the only cars that is compatible for my Transmission if I'm not mistaken?
    Sent from my SM-N950U using Tapatalk
  2. #2 Re: **HELP** 04 GTP SC shifts but wont drive
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by showtastiik View Post
    Those are the ones! That being said, you'll want to look at the top where the shifter attaches. You'll need the one that matches your transmission. One is inside one is out. I think there's a way to re- do the wiring, again bill boost did that write up, but that might only work for the older models. The only exceptions to this are the comp-g and gxp which are specific to those models, though if you have comp-g, I bet you can use regular and just tune the codes out.
    The only difference between hd and non is the differential (held on by 4 bolts and a clip).I doubt your stock one is damaged, so you could get one from an n/a and swap the differential making it "hd" if you have a hard time finding good hd ones, plus the n/a ones tend to be driven softer since no supercharger.
    Watch out on the gear ratios since some other w- body cars used different gear ratios. If you search the forum on gear ratio it should come up.
  1. all wheel drive drive rain with 3.8 engine
    By fisheson in forum General Grand Prix Discussion
    Last Post: 03-11-2016, 12:13 PM
  2. GXP clunk from park to drive, drive to reverse..
    By sasquatch094 in forum General Tech Discussion
    Last Post: 02-13-2014, 04:27 PM
  3. Drive side door wont unlock
    By ffbwizard in forum General W body
    Last Post: 01-02-2014, 01:41 PM
  4. Wont upshift 2-3 but down shifts 4-3
    By bstuby in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-03-2011, 08:40 AM
  5. 1998 gtp wont drive in 4th NO SLIPPING THO
    By beno420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-21-2011, 11:23 PM
