The main reason is that by blocking the coolant ports here, you can remove the supercharger/ upper plenum and throttle body without having to drain and bleed the coolant system.
Other main one is those wanting to run an intercooler.
There's other minor reasons that all have their controversy, like it keeps your throttle body colder, you can use throttle body spacers, less likely to leak, L36 coolant and egr issue resolved, etc. (I'm sure I'm missing a free)
The porting is to try to increase the coolant flow rate, especially if the throttle body is bypassed since you are removing that branch of the coolant flow. This is highly debatable, but I'm running nearly 10 degrees cooler on a stock system and thermostat after the port.
Hope this helps!
