Thread: 5V On Ignition Circuit and Car is Going Crazy
Results 1 to 8 of 8
  1. #1 5V On Ignition Circuit and Car is Going Crazy
    Jul 2010
    Dubuc, SK
    Hello all,
    My sister has an 04 grand prix GT that has been having some strange issues lately. At first she lost all power inside the vehicle, as in no lights on anything inside the vehicle, no gauges worked, nothing power inside the car except headlights and brake lights. Even the signal lights didnt work. The car would still start and drive. Now when I go to start it, the security light flashes crazy, and the fuel pump and ignition relays are cycling on and off like crazy. I measured the voltage on the ignition circuit when the car is trying to start, and it starts at 5 volts and drops down lower as it goes. Anyone have any clue what could be causing this? It seems to me like its a short in the ignition circuit somewhere. Could it be the ignition switch itself? Not too sure what else to narrow down. Any help is appreciated. Thanks!
  2. #2 Re: 5V On Ignition Circuit and Car is Going Crazy
    check the battery posts "clean and tight" and the main grounds on the trans bell housing. the small black grounds tend to break off the eyelet.
  3. #3 Re: 5V On Ignition Circuit and Car is Going Crazy
    Jul 2010
    Dubuc, SK
    Thanks for the quick reply, I will go check that ground out and double check the terminals. I am leaning towards there being a short somewhere in the ignition circuit or the PCM though as all power is fine until its switched to accessory or run.
  4. #4 Re: 5V On Ignition Circuit and Car is Going Crazy
    you'd be amazed what a bad ground or dirty battery post can do.
    you guys got a crap ground cable set up on the 04 ups iirc. make sure any small wires off the ground cable are also tight. like to the fender if theres one.
  5. #5 Re: 5V On Ignition Circuit and Car is Going Crazy
    Jul 2010
    Dubuc, SK
    Ok I checked the grounds on the transmission housing, probably 4 or 5 little ones off of there and they seem fine. I also checked the main ground that goes to the fender area bellow the battery and that seems good. I put the battery on the charger for a while and it will now start at least, but still no gauges or any electronics inside the vehicle. Not too sure where to go next. It does have an aftermarket remote starter, so maybe there's something up with that.
  6. #6 Re: 5V On Ignition Circuit and Car is Going Crazy
    Jul 2010
    Dubuc, SK
    Just an update, changed the ignition switch, but still have no power to the interior. There is no power on the interior fuse block. What powers up the interior fuse block? Thanks.
  7. #7 Re: 5V On Ignition Circuit and Car is Going Crazy
    Oct 2014
    portland oregon
    IDK what powers it for sure but i do know you can google the wiring diagram for it and use it to follow the leads and check for issues also can check the engine bay fuse block since it has interior fuses and relays in there to
  8. #8 Re: 5V On Ignition Circuit and Car is Going Crazy
    Jul 2010
    Dubuc, SK
    Thanks, found some electrical diagrams, but leaning towards it being the Body Control Module now.
  1. p1200 (injector circuit)
    By Jomamma in forum General Grand Prix Discussion
    Last Post: 10-14-2013, 07:41 PM
  2. Help p2535 ignition switch run/start position circuit high
    By Jsdorman5 in forum General Tech Discussion
    Last Post: 10-05-2013, 07:02 PM
  3. New Guy Here, Looking for circuit breakers
    By kevinj04 in forum General Tech Discussion
    Last Post: 08-01-2011, 05:23 PM
  4. P0480 Fan Control circuit
    By s10350 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 05:49 PM
  5. what is on the horn circuit?
    By Bio248 in forum General Tech Discussion
    Last Post: 11-25-2008, 01:05 AM
